Throttle body upgrade / swap options?
Started by metroplex, February 11, 2017, 08:45:50 AM
metroplex
Does anyone know of any throttle bodies that can be swapped over to the SHO? Perhaps an aftermarket 3.7 Mustang's 73mm throttle body? The reason I ask is because I sealed the throttle body motor cap with a vacuum cap (the cap that a lot of us have lost) and a replacement cap, the vacuum cap collapses under idle / vacuum and gets inflated under boost. This tells me that everyone that has lost the cap is essentially suffering a vacuum/boost leak at the throttle body plate seal.
I looked at the F-150 EcoBoost and Mustang EcoBoost throttle bodies and they all use a model of TB that has a sealed motor (the plastic is a slab side design, no removable cap). The model of motor that we are using was used as far back as the 2005 Mustang that was never really intended for a turbo application. GM's GTDI LNF throttle body (used as far back as 2006) is the same style as the F-150/Mustang EcoBoost throttle body, so there's no chance of a boost leak like ours.
Previously: 2014 SHO
12.4 @ 110.9 mph
Current: 2017 Fusion Sport
hawkeye93
I know the F-150 TB has a different bolt pattern than the SHO TB, so it won't bolt to the manifold directly.
2015 Ford Taurus SHO PP 12.219@112.84
PPE catless DP, Gearhead IC, SP-534, Reische 170, 3 bar, hybrid meth system, tunes from Unleashed, Livernois, Brew City Boost & AJP
1965 Ford Mustang Convertible 289 4V/T5Z/3.55
1955 Ford Fairlane Club Sedan 272 4V/Fordomatic
Gray Brick
BBK might offer one.  I will be there on Tuesday and ask.
2013 Ecoboost Ford Flex
metroplex
The BBK's for the S197 Mustangs required the motor to be swapped over (and those used the same or similar motors as ours with that stupid dust cap that pops off). It'd be great if they could make one similar to the EcoBoost F-150/Mustang where everything is sealed properly. Please let us know what you find out!
12.4 @ 110.9 mph
