Which version of the tune do you have, what fuel (and which gas station) are you using? Winter fuel is weaker than summer fuel, so if you want to go WOT, you should use a 91 tune with 93 or higher octane fuel. How long have you been running this tune, and was it problem free when it was warmer?
Plugs should be gapped to 0.030 per LME. Are you using NGK plugs? Also, going to WOT requires that the engine and trans be fully warmed up before you do so, else you run the risk of engine failure.
