I've tried both the Reische 170 and the LMS 160 several times. I prefer the Reische 170 even though I use an LMS tune and have been very satisfied with LMS support. The Reische thermostat, I believe is a "cold sided" thermostat that works more consistent with the the eco boost. The LMS 160 TS is a "hot sided" TS. It is a good quality TS but seams to be more erratic than the Reische because of the difference between the hot sided and cold sided TS. With the LMS 160 I would definitely see Lower temps at times, but the problem was I would also see higher temps during cruising, idle or normal driving than the 170.
Sent from my iPhone using Tapatalk Pro
