July 20, 2019, 01:32:51 AM
Author Topic: Transmission drain and fill  (Read 2451 times)
Offline SM105K
  • : Arizona
  • -Given: 525
  • -Received: 586
  • Land Yacht Pilot
Re: Transmission drain and fill
« Reply #15 on: March 25, 2019, 01:28:42 PM »
I had the Ford dealer perform a Trans flush which they hook the trans flush machine up to it and do a flush through the dip stick. It will still use 10 qts of fluid.
I believe it was $99.00 for this procedure IIRC! Z
I thought flushes were not recommended? By the time you get done buying 18 quarts of fluid, doing three drain and fills, its cheaper to have a shop do the flush...
Even doing the flush (which isn't recommended) only removes 10 out of the 18 quarts.  Yeah doing the exchange over a period of time is more expensive, and yields more fluid exchange while not being as abrasive on the internal parts of the trans.  I don't want a vac hose being rooted around my trans personally.
No need to get Technical! Lol. Z   :D
I used 10 quarts Total.
I am "special" and really gun shy about my trans.  I will be doing the trans fluid exchange (5 out, 5 in) every 3k miles along with my oil change.  Completely overkill yes, but overkill is good.
So is the drain and fill 5 or 6 quarts?
Technically whatever your take out.  Mine is usually around 5 quarts.
2013 SHO PP: AJPTurbo E30 Tune, GH Intercooler, Dicunzolo Gen2 Trans Mounts, UPR Catch Can, H&R Springs, Power Stop Brakes. Tune Only: 12.56@108.98, 391HP and 470TQ
2013 Focus ST: Ford Racing Tune, Boomba BOV, and Short Shifter.
Offline BlueSHO
  • : Crete, ILliNoIS
  • -Given: 109
  • -Received: 98
« Reply #16 on: March 25, 2019, 01:31:39 PM »
10-4
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 11283
  • -Received: 3732
« Reply #17 on: March 25, 2019, 01:36:36 PM »
FWIW- Here is the actual response from the Ford dealer. We cannot do an actual Trans Flush, what we do is hook the trans flush machine up to it and do a flush through the dip stick. It will still use 10 qts of fluid to do the service. Dunno!
I apologize for the confusion. Z
Makes sense IF
The drain plug is out, and
The engine is running to allow the trans pump to work.
Offline Gray Brick
  • Sr. Member
  • : Southern California
  • -Given: 32
  • -Received: 80
  • Gray Brick
« Reply #18 on: March 25, 2019, 04:15:13 PM »
I drain and fill on every oil change and get 5-6 quarts exchanged.
I really should be doing this more often on the PTU.
2013 Ecoboost Ford Flex
AJP Tune (ATP+2) in progress , Livernois HPFP, 3 Bar MAP, UPR Catch Can, 100% Methanol w/ braided steel lines, 3" Downpipes -->2.5" X-pipe --> 2.5" Magnaflow exhaust, 2.5" air inlets to each turbo with cone filter, Custom water to air intercooler with chiller
275/40-20 Front 315/35-20 Rear Tires
---7.931/90.76MPH @ 5150 lbs in the 1/8th---
Offline SM105K
  • : Arizona
  • -Given: 525
  • -Received: 586
  • Land Yacht Pilot
« Reply #19 on: March 26, 2019, 06:32:23 AM »
I see you are crazy like me too.
Offline nickstewartroc
  • Full Member
  • : Orlando, Florida
  • -Given: 6
  • -Received: 63
« Reply #20 on: March 26, 2019, 09:53:11 AM »
I won't be doing the transmission fluid that routinely, but I do change the PTU fluid along with my oil changes. Even after 5-6k miles the PTU fluid breaks down tremendously
Current:
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 11283
  • -Received: 3732
« Reply #21 on: March 26, 2019, 10:01:16 AM »
What fluid ate you using, Nick?  Is it ester based?
Offline BlueSHO
  • : Crete, ILliNoIS
  • -Given: 109
  • -Received: 98
« Reply #22 on: July 13, 2019, 11:53:47 PM »
Just finished the drain and refill on my SHO. The drain plug is 7/16 and the lower plug on the case. There is one higher up so it's the lower one which makes sense. Used the motorcraft LV fluid and did it the first time and let it circulate and get up to temp then did it a second time. Took about 5.5 quarts for each time.
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1559
  • -Received: 3440
« Reply #23 on: July 14, 2019, 09:41:28 AM »
<a href="https://www.youtube.com/embed/9xrP6N6hVIc" target="_blank" class="new_win">https://www.youtube.com/embed/9xrP6N6hVIc</a>
  Z   :)
« Last Edit: July 14, 2019, 05:06:44 PM by ZSHO »
2013 Performance Package SHO| Livernois Custom Methanol Tune|3-Bar Map|Reische-170-Stat|Full Race Tial-10psi BOV in Black|PPE-Gloss Black Hot Pipes|PPE Catted DP|Corsa Sport Cat Back Exhaust|H&R Sport-Springs|Airaid-Dry-flow-CAI|CFM Performance Billet Valve Cover Breather In Gloss Black|Llumar 20%Ceramic window Tint|MSD Ignition Coils in Black|Extreme Roof Spoiler|Redline Fluids all around|Gearhead Intercooler|First-SHO With Direct Port Alky-VP-M1-100%-Methanol Injection|LMS-Custom-Dyno-Tuned @ 415whp-465wtq| Best Trap Speed of 115.54 mph|
Offline BlueSHO
  • : Crete, ILliNoIS
  • -Given: 109
  • -Received: 98
« Reply #24 on: July 14, 2019, 02:13:17 PM »
   https://youtu.be/9xrP6N6hVIc    Z   :)
Yep good old Brian he has many good videos.
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
* Featured Topics
* Recent Topics
by MKS Tom | July 19, 2019, 11:08:07 PM
Is it possible to get into the 10s?  I mean, ANYTHING is possible...
Re: Any roofers?
by FoMoCoSHO | July 19, 2019, 07:35:39 PM
Home inspectors, jack of all trades master of none.It needs sisters......
Re: Inferred Octane
by FoMoCoSHO | July 19, 2019, 06:10:48 PM
Is OAR another way of displaying inferred octane? Or is more of an ind...
by SHOdded | July 19, 2019, 04:06:00 PM
Big moves :)...
Re: I-G35!
by shoNoff | July 19, 2019, 01:35:44 PM
Good idea on the roof. Car looks awesome. It amazes me how up to date ...
Re: Queens addition
by Dxlnt1 | July 19, 2019, 01:01:26 PM
RIP to the goat! Pure Pontiac muscle. Another true sleeper car that on...
Re: Yet another failure
by polskifacet | July 18, 2019, 05:20:16 PM
There are 1000s of diffs because the "carrier" is the same a...
Re: rough idle no accel response and P0087 code
by Livernois Motorsports | July 18, 2019, 02:10:28 PM
That is excellent news!  Glad to hear that module did the trick.&...
Re: A sad, sad day in the history of my SHO.....
by TopherSho | July 18, 2019, 09:00:24 AM
I have a few more things to add, I have read this whole tread many tim...
Re: Random questions and shameless plug
by Black Dream | July 17, 2019, 07:48:34 PM
I haven't dug any deeper yet.  I bought new headlight bulbs ...
Re: Saw a Potential Upgraded Transmission on FB
by JagerBomb | July 17, 2019, 12:42:16 PM
Just to update, N. O. fell off facebook and had a falling out with oth...
Re: Taurus sho trans upgrade
by JagerBomb | July 17, 2019, 12:38:59 PM
Is there any company working on performance upgrades for the 6f55? Sen...
Re: "How-To" wire up a switch so you can manually turn the fans on - Kolk1
by TimmyATL | July 17, 2019, 08:55:55 AM
Yall might want look at the wiring diagram for the cooling fans. On my...
Re: AWD off message on long drive
by SHOdded | July 16, 2019, 04:52:53 PM
If the tires prove out then yes it would seem.  Or maybe the not ...
Re: Change out headlamp bulb - MKS vs SHO???
by Simonsays | July 15, 2019, 06:12:03 PM
My mks had torx screws holding it in as I have adaptive turn lights. I...
Back to top
