Upgraded HPFP
Started by FoMoCoSHO, November 06, 2016, 02:42:56 PM
Blackhawk
The guys making the pumps said on facebook that the stock injectors are fine to run the 30-40% more fuel the upgraded new pump can push.  We'll see when someone actually gets the pump running and tested.
Quote from: FoMoCoSHO on November 07, 2016, 11:40:04 AM
I'm pretty sure you would need the +30 deatschwerks injectors to run the higher e blends.
I assume then the fueling and maintenance requirements would have to be more rigorous also, considering how many people have had the stock/OEM injectors fail.  How would you verify their condition prior to switching over to this new HPFP?
Frozen Blue
Quote from: SHOdded on November 07, 2016, 12:04:36 PM
Have them flow tested.
2013 SHO non-pp
3 bar Map, 160° tstat
Powerstop Z23 rotors/pads
LMS v10
bamsho
I saw price of $1900, OUCH!  I know there  is R&D, seems overly high.  I was hope maybe around the price of a meth kit.  Going to let others try it first.  Can buy alot of methanol for $900.
Quote from: Frozen Blue on November 07, 2016, 01:39:54 PM
Thats the thing, it is a bit of labor to get to them and then reinstall them, would have to be DIY.  I suppose a relative flow test would have to do instead.
derfdog15
Quote from: SHOdded on November 07, 2016, 04:05:16 PM
Probably future tech, but a flow sensor for each cylinder would be pretty awesome, or a way to tell if everything is proper based on individual injector voltage/ecm signal.
That would be COOL :)  Heck I would settle for a boost and oil pressure gauge straight from Ford LOL!
derfdog15
Quote from: SHOdded on November 07, 2016, 06:09:20 PM
The 1 thing I hate about the SHO is the electronic cluster without additional gauges. Even the crappy H/L analog gauges would be better IMO. On my SHO it was a simple fix with a Crash pod though and boost and A/F.
Once you get used to having gauges, nothing else will do.
I wonder if there are ways to build safety into a tune based on fuel pressure dips, I assume you can narrow down atleast which side of the engine an issue is occuring (fuel wise) based on Bank A/F
NITSOOB
So.. this thing is out already, from Livernoise. Two versions. Approx 1600, or 2400 for severe duty. Rich over on the ecoboost enthusiast FB page has it up on running. I about s*** myself. Full E85. But hes maxed out injectors.
2013 PP SHO - 3.5" DPs, 3.5" Exhaust, 3" Coldside
Pending: 5-Blade billet wheel, AJP Tune
1/8: 8.4@86
bamsho
Maxed out injectors, sorta.  The ECU is the main issue.   2010-12 have different from 2013+.  There are more tables to work with the '13+ cars.  So sounding like guys with the 2010-12 cars may have to get injectors.  That's what I got out of it, this past weekend.
Quote from: NITSOOB on June 06, 2017, 09:42:07 PM
Rich is NOT running full E85.
Brian is correct, in stating the injectors are an issue for those '10-'12 model years.
I believe Rich is running about a 50% E blend from what I recall.
Sucks being the test mule, but y'all should be thanking Rich for his headache's and whatnot involved in enduring all the ironing out this has to go through, before the rest of y'all can enjoy it full tilt.
NITSOOB
From FB:
QuoteYeah...have a full e85 tune,just couldn't turn it up as much as we wanted and be safe
According to him, it should be available for purchase
1/8: 8.4@86
Correct, he couldn't "turn it up much".
I.E. not running full E85 due to the injector issues currently presented.
Quote from: bpd1151 on June 06, 2017, 10:12:25 PM
True!! actually ran into Rich's car on the Dyno at LMS while picking mine Up. Z
Its sometimes better to be on the safe side of things for the Time being. Z
NITSOOB
I see.. Im reading as: hes turned down boost due to the injector issue. Reached out for clarification.
This is pretty amazing either way,  full e85  or close to it.
1/8: 8.4@86
