Nice work! I did the same thing with mine. One other option is to mount the remote "panel" (mute and red indicator) under the Start/Stop button. I ran the wire across the bottom of the dash under the steering wheel panel (behind the OBD2 connector) and popped it out at the seam in the panel and just double sticky taped it. You can see it through the bottom of the steering wheel but it's very discrete...I keep the detector dark on top.
