How to: Access Engineering Mode in Dash Display on 13+ SHOs
Started by SHOdded, October 29, 2016, 07:42:11 AM
ToMang07
Quote from: ZSHO on August 10, 2018, 01:57:25 PM
Quote from: ToMang07 on August 10, 2018, 10:44:25 AM
I cannot get this to work with my '13.
Whats the Build date on your 2013MY!  Z
Did you press the ignition,start button(once)while having the Key Fob inside the vehicle!.
While holding the OK button on the left side of the steering wheel for five seconds,immediately press the push button start again which is (ignition mode) and that will Access (Engineering Mode) which the speedometer will then perform a sweep test and then just use the up/down buttons on the left side of the steering wheel to scroll,navigate you through the options.........
I was letting off the "ok" button too soon... holding it after hitting the ignition did the trick,  thanks!
Sent from my SM-G960U using Tapatalk
~Tom~
2013 SHO - Stage 3 Snow Performance Meth, (2) SCT X4 with Unleashed, 3 Bar Map, MSD Ignition Coils w/Colder Plugs 170*TS, EcoPowerParts Hot Pipes & Tial-Q BOV) Stage 3 Motorsports Catless Downpipes 3" Cat-Back Exhaust, JLT Oil Separator, H&R Sport Springs, K&N CAI, Drilled and Slotted Rotors w/EBC Pads
Quote from: ToMang07 on August 10, 2018, 02:05:53 PM
Glad its working. Z  :thumb:
FiveLeeter918
- Lee
Ortiz Performance Vendor Forum | Find us on Facebook! | Shop Today!
