Finally got some more time to play don't know if anyone else has had these same questions but autounlock driver 1-4 I'm guessing is for each driver key not sure how you would program what is 1 thru 4 but I think I remember when I got my keys it was labeled what one was the master key so I picked that one gave my wife the second one so that should be 1 and 2 then how ever you add the next chooses 3 and 4
I'm guessing autounlock vehicle level is just when you drive off it will autolock
I found d out two stage unlock is just how many times you hit unlock on the fob one stage unlock all four two stage driver then the 3 others
Pase configuration I tried inop I don't know what that stands for but makes it where the key has to be in the chip holder spot to read the key to state the car
Haven't tried disabled affraid it may not let me use the push start button to let me reconnect and change it back
Not sure what passive keyfob does key still works when I disabled to lock unlock and start car using the touch sensors or from key
