- Full Member
- Ecobooster
- Logged
Quote from: derfdog15 on October 30, 2016, 09:44:05 PM
Quote from: J_C on October 30, 2016, 10:46:17 AM
Quote from: derfdog15 on October 30, 2016, 10:03:30 AM
Is your car PP or not? Advance-trac/traction all the way off when you launch? Do you break boost? If so, what RPM? Thats a pretty nice 60'
Yes, it is a performance pack. I only turn off traction control because wheel hop hasn't been an issue before. Makes me wonder if it would've helped me more turning advance trac off also because it lit up on the dash around 100mph each pass. Yes, this was a break boost launch btw
Shoulda read the signature for the PP question... DOH! What RPM are you launching at? I know all cars are different, just trying to see if it is drastically different than my launch.
Quote from: J_C on October 30, 2016, 12:45:45 PM
I can't help but wonder if the wheel hop and advance trac cost me a tenth or two? I kept dropping tire pressure hoping it would help but didn't unfortunately
As other have said, Advance-Trac, even off, gets pissed when you go fast. I had the same thing AJP mentioned happened ~3 times at the track the last time I went, but a quick key-cycle set everything straight. No actual codes, etc.
I have yet to get wheel hop, I wonder if the H&Rs spring rate was a contributing factor there?
Yeah, nothing lit up on my dash at launch or on the 1-2 shift it wasn't until 100ish that advance trac kicked in. It probably didn't help I was spinning the tires after the water box before staging either. I doubt it was my springs because it hasn't wheel hoped on previous trips with the springs installed
2013 Taurus SHO performance pack: H&R's, Aem drop in filter, Torrie e30 tune, 3 bar map, 170 t-stat, Unleashed catless downpipes, Vibrant resonators, 4" rolled tips
12.172 @ 113.06 mph
