2013 XSport Tuning
Started by MiWiAu, October 24, 2016, 01:58:58 PM
derfdog15
Quote from: 16MagSport on November 14, 2016, 11:13:09 AM
FYI, mine has always measured -0.96 with 91 octane.  When I added 96 and 100 at the track to get me a 93-95 octane mix, it still measured -0.96 so I think that is maxed for mine.
My SCT Pegs/maxes out at -.96 as well. I think it is possible to play with the limits of the value within a tune for finer readings/readings past -1 though if so desired.
MiWiAu
Thanks guys. Last time I ran a tank of premium (91 no ethanol from a station way out of town), I was at -0.98 to -0.96. When I switched back to 87 to start my new tunes with AJP, the OAR dropped pretty quickly (within 20 miles) and settled at -0.33 through 2 tanks of fuel. It just seems to be taking a lot longer to adjust this time.
On a side note, I was under the impression that OAR was stored in KAM and that clearing it should reset OAR to a default value. This is not the case with my X4, since my OAR does not change after a KAM reset. I sent a note to SCT yesterday asking if the X4 should be capable of resetting this value, and they replied saying I needed to set up a remote support session to look into my issue (no definitive answer given). I won't be able to call during their support hours until tomorrow morning, but I'll let you know what they say.
2013 XSport
derfdog15
Quote from: MiWiAu on November 14, 2016, 11:23:57 AM
OAR should be a KAM item, however this was noted a few days ago in a SHO related post as well (can't remember the topic or I would point you to it).
The speculation was that the change to PCM/ECU between the '12 and older SHO vs. the '13+ SHO may be the reason, as on the older SHO the KAM reset (and even just general tune flashes) reset OAR. On the 13+ many people (myself included) noted that it did not change, with a reflash or a KAM reset.
It would be awesome if SCT found a way to do it on the 13+ SHO.
I assume the XSport shares similar changes/behaviors
Quote from: derfdog15 on November 14, 2016, 11:21:28 AM
That is correct, mine scales to -1.15
MiWiAu
On my drive home today, I focused on light throttle/boost trying to allow the KR climb as far into the negative region as possible for as long as possible. KR maxed out several times at -3.99 (adding spark). After about 10 miles, OAR went from -0.76 to -0.79, then about about a half mile later it jumped to -0.96.
I'll still follow-up with SCT in the morning to see if they can offer any response to the OAR not clearing with KAM reset, but at least I think I can expedite the OAR relearn in the future, if they cannot provide a solution.
Thanks (again) for the help!
2013 XSport
