February 24, 2021, 11:54:27 PM
Author Topic:  ProMeth Says Hello - Manufacture of Ecoboost Water Methanol Injection Systems  (Read 35459 times)
Offline PROMETH
  • Jr. Member
  • Oxnard< CA
  • -Given: 0
  • -Received: 7
  • EcoBoost Methanol Injection Systems
    • ProMeth - Manufacture of EcoBoost Water Methanol Injection Systems and Components
  • Liked:
  • Likes Given: 0
By chance, are you looking to build a tank for the SHO engine bay? Preferably one with the pump attached to it.
The direct port for the SHO looks great. Are they any test results?
Last- who makes your pump, and what is the warranty on them? This community has learned (the hard way) that over time meth corrodes the pump requiring a replacement.
Unfortunately not. The tooling is very expensive and the market is to small for the SHO. The demand just isn't there for us like the Mustang which is next.
Waiting on customers to do before and after testing. Direct port is the only fix for distribution problems. You can't mount a single nozzle out in front of the throttle body or worse mount nozzle in the throttle body spacers and expect the injection to flow evenly to every cylinder. Unfortunately, it just doesn't work out that way. The manifolds were never designed for wet flow. The injection wants to go to the rear of the intake manifold. Look at the feedback and results on the auxiliary fuel injector systems which placed two fuel injectors in a throttle body spacer vs the port injection systems. The throttle body systems had sever distribution problems. Port injection is the only way to precisely meter how much fluid water meth is sprayed into each cylinder. This is why we have half sizes down in the lower range of nozzle size options we offer. We've been doing direct port injection for years and not every cylinder needs the same amount. When we have cylinders that are running hotter than other we can adjust accordingly through our jetting. We carry 23 sizes of nozzles.
Three year warranty of pumps when with purchase of system. 1 year warranty of parts.
http://prometh.com/pages/warranty-policy
Aquatic makes our pumps. We are the only company using the 1.5 amp motors as well. We did all the testing and have been using them now for the past two years. Our pumps provide 30% more flow over the competitors 10-11 amps motors. The rpm of the motor is one thing. We've also had Aquatic perform other modifications to get more flow. We work with a lot of high horsepower applications which were requiring two pumps. We can now support 1100-1200 horsepower at the tires with one of our pumps
Website: www.prometh.com
Email: rodney@prometh.com
Hours: Monday-Friday 9am-5:30pm PST
Phone: Phone: 801.447.2559
Instagram: prometh_injection
Offline PROMETH
  • Jr. Member
  • Oxnard< CA
  • -Given: 0
  • -Received: 7
  • Liked:
  • Likes Given: 0
welcome!
website in Sig doesn't work
Signature fixed. Thank you for the heads up.
Offline J-Will
  • -Given: 68
  • -Received: 106
  • Liked:
  • Likes Given: 0
Thanks for answering my questions and providing more insight into your business.
I am very excited to have you as a member on this board.
3-bar
SP-542 plugs w/ GH gap
Offline PROMETH
  • Jr. Member
  • Oxnard< CA
  • -Given: 0
  • -Received: 7
  • Liked:
  • Likes Given: 0
welcome! I'm sure you guys will be a lot more reasonable to work with than Snow Performance has proven to be!!
Our business model is a bit different. We do a lot of custom work and work more closely with our customers. We offer custom manifold installations, welding, fabrication, build custom hoses in house , both hardline and braided hose assemblies, that you won't get from our competitors. We are happy doing a few custom systems each day. Our competitors are doing 20-50 systems a day. We are a much smaller company.  Hose systems is an area that we are currently working on improving. For example, the stainless steel flared hard lines is a much higher quality hose system than the push connect fittings with nylon. The cost isn't that much more than doing direct port in plastic nylon hoses so why wouldn't you go stainless.  It last a lifetime, eliminates phone calls and replacement fittings and looks so much better.
Another new product we've been working with for the past 6 months is your Sniper injection systems. This was developed working with our non-intercooler outlaw drag racers and grudge cars. We can move a ton of methanol in a confined area, saturating the air charge, lots of initial contact area, great for high boost non-intercooler applications.
We are also the worlds first and only company to offer pumpless water methanol injection systems. I designed and developed two packages which we use on our nitrous engines and for our high horsepower (1500-3000+ horsepower) turbo and supercharged cars.
Once we have our controllers in stock we will be launching a lot of new system packages and options as well.
Offline PROMETH
  • Jr. Member
  • Oxnard< CA
  • -Given: 0
  • -Received: 7
  • Liked:
  • Likes Given: 0
I have been buying pumps, nozzles, and other parts from Rodney @ ProMeth.
I would recommend him in a heartbeat!!!!  He really knows his stuff. :)
Thanks for the comment and support!!
Offline Linemonkey
  • Full Member
  • Seminole, Tx
  • -Given: 110
  • -Received: 38
  • Liked:
  • Likes Given: 0
Great looking products. How difficult is the installation of your direct port/7th injector system, on the SHO? Is it necessary to remove the intake? I'm no novice, at wrenching, but not a pro, either lol. Thanks
Sent from my SAMSUNG-SM-G930A using Tapatalk
2013 SHO PP Tuxedo Black
3 bar
160 T-STAT
Catless DPs
Tune by AJP
Offline EcoPowerParts
  • How can I help you today?
  • Vendor
  • Phoenix
  • -Given: 147
  • -Received: 1244
    • EcoPowerParts
  • Liked:
  • Likes Given: 0
Welcome, thanks for joining and FYI you need something for my other vehicle - '11 CTS-V :)
Offline SHOurpp
  • Full Member
  • pa
  • -Given: 117
  • -Received: 18
  • born again hard
  • Liked:
  • Likes Given: 0
what kind of under hood tank do you guys have for the 4th gen sho?
duel 3 inch cat less down pipes
sct x4- as a scanner/logger only
3 bar map
hp tuners
both bovs vta
Offline PROMETH
  • Jr. Member
  • Oxnard< CA
  • -Given: 0
  • -Received: 7
  • Liked:
  • Likes Given: 0
For the Sho you need to remove the intake and mill the back side flat on the intake runners. To make this go easier I have intake manifolds here that are already machined and with the injection installed ready to bolt on. There is a core charge of $250 which we credit you back if you send you manifold back into us.  If you want the manifold powder coated this is also something we can do. Manifold complete with injection installed is $499.99 shipped
Let me know if you have any other questions or how I can help.
Offline PROMETH
  • Jr. Member
  • Oxnard< CA
  • -Given: 0
  • -Received: 7
  • Liked:
  • Likes Given: 0
This is the least expensive tank we carry for under the hood. Its three quarts and comes with brass vent and sight tube which you can install on either side of the tank. Here's a link to all the tanks we carry and manufacture.
https://prometh.com/collections/tanks
Offline PROMETH
  • Jr. Member
  • Oxnard< CA
  • -Given: 0
  • -Received: 7
  • Liked:
  • Likes Given: 0
I just had a request for this very thing. I need the upper lid to the supercharger to make a kit.
Offline Rockstar04
  • Full Member
  • Illinois, USA
  • -Given: 6
  • -Received: 17
  • Liked:
  • Likes Given: 0
2016 Explorer Sport - Bone Stock
Offline PROMETH
  • Jr. Member
  • Oxnard< CA
  • -Given: 0
  • -Received: 7
  • Liked:
  • Likes Given: 0
That direct port setup is very nice looking!
Thank you. You can see pictures of it installed on our instagram page. The first layout had fitment issues and required doing the lines differently. This fits with out any issues. This system will last a life time and never have the issues like the plastic hoses and push connect fittings.
Offline SHOurpp
  • Full Member
  • pa
  • -Given: 117
  • -Received: 18
  • born again hard
  • Liked:
  • Likes Given: 0
where exactly does it go?
have a picture installed?
thanks
3 bar map
hp tuners
both bovs vta
Offline Vortech347
  • Sr. Member
  • Layton, UT
  • -Given: 33
  • -Received: 114
  • Fastest Realtor.
  • Liked:
  • Likes Given: 0
I've been trying to tell people this for years.... Glad to see a vendor talking right on theory rather than just trying to make money.  DIRECT INJECTION FOR THE WIN!!!
Matt H.
2013 SHO Performance Pack, Daily, AJPTurbo tuned
2003 SVT Cobra 497rwhp/491rwtq, Self tuned, Cruiser
1990 Mustang GT 570rwhp/530twtq, Self tuned, Open Track
2017 F150 XLT 5.0
* Recent Topics
Re: Brew City Boost no longer to offer tuning.
by TopherSho | Today at 08:42:42 PM
There's new rules coming out or out concerning modifications of t...
by bpd1151 | Today at 12:22:55 PM
02/24/2021.......Engine builder LMK that internal trans parts have bee...
Re: Converting kPa to PSI?
by Admin | February 22, 2021, 08:08:20 PM
https://www.convertunits.com/from/kPa/to/PSIThis website is great, rem...
Re: RockAuto Wants To Help With Your Upcoming Car Show
by Macgyver | February 19, 2021, 06:34:46 PM
Outstanding Idea !!!...
Re: 2020+ Explorer ST Parts and Tuning Now Available at Ortiz Performance!
by Macgyver | February 19, 2021, 06:33:36 PM
Are you planning or already have the Edge ST ?...
Re: HPTuners Updated Support for 2013-2018 Taurus SHOs
by BOT_ROCKET | February 19, 2021, 05:21:20 PM
No worries on the delay. I totally understand. It got pretty chilly he...
Re: So the tax lady was good to me
by FiveLeeter918 | February 19, 2021, 03:21:46 PM
Hey bud, luckily all of the MKS and SHO stuff is interchangeable. Let ...
Re: &quot;Engine coolant temperature too high&quot;
by ChrisxHowe | February 17, 2021, 01:42:47 PM
Sent from my iPhone using Tapatalk...
2011 Ford Taurus SHO $11,000 Orange Cnty, CA
by dinkydingo | February 16, 2021, 01:18:15 AM
For sale is a 2011 Ford Taurus SHOThe car has had some work done in or...
Re: 2017 Black Ford Edge Sport:
by FoMoCoSHO | February 15, 2021, 03:01:41 PM
unleashedtuning.com and Torrie McPhailIf you really want to go all out...
