February 25, 2021, 12:42:50 AM
Author Topic:  ProMeth Says Hello - Manufacture of Ecoboost Water Methanol Injection Systems  (Read 35469 times)
Offline PROMETH
  • Jr. Member
  • Oxnard< CA
  • Thank You
  • -Given: 0
  • -Received: 7
  • EcoBoost Methanol Injection Systems
    • ProMeth - Manufacture of EcoBoost Water Methanol Injection Systems and Components
  • Liked:
  • Likes Given: 0
i am looking for a meth/water tank that fits under the hood of a sho
so you have any or kits?
I have these in stock. Here's a link to our page.
http://prometh.com/collections/tanks/products/example-product-02?variant=10679958659
Features Include:
3 Quart
Brass vent
Level sight gauge
Plastic screw on cap
Mounting hardware
Blow molded construction
Made from high density polyethylene
Will not stain or discolor as white tanks
100% methanol compatible
Dimensions: 8.75" tall x 8.75" wide 4.25" deep
Special Notes:
Does not include tank outlet fitting shown in picture.
Tank outlet fitting is provided as an option.
Sight level gauge is included but not installed.
Instruction for installing sight level gauge provided.
Website: www.prometh.com
Email: rodney@prometh.com
Hours: Monday-Friday 9am-5:30pm PST
Phone: Phone: 801.447.2559
Instagram: prometh_injection
Offline FoMoCoSHO
  • Super Moderator
  • Elite Member
  • Thank You
  • -Given: 705
  • -Received: 1157
  • The Tenth Man
  • Liked:
  • Likes Given: 1
You guys don't happen to design intercoolers do you?
We really need an efficient FMIC.
No, we do not design intercoolers. Just water methanol injection systems and components. There are plenty of aftermarket intercoolers being made for the Ecoboost engines.
Not for the transverse 3.5....
If you happen to know of someone, please let us know!
Offline PROMETH
  • Jr. Member
  • Oxnard< CA
  • Thank You
  • -Given: 0
  • -Received: 7
  • Liked:
  • Likes Given: 0
I'm most interested in your controller options.
Can it control multiple lines? One for the direct port setup, and one line for the 7th nozzle (not connected to the distro block of the direct port)
We are working on a two stage controller so you can open a solenoid at a separate point.
Offline PROMETH
  • Jr. Member
  • Oxnard< CA
  • Thank You
  • -Given: 0
  • -Received: 7
  • Liked:
  • Likes Given: 0
I wouldn't know of anyone. If its not available you can always build an intercooler. Many of the race cars I work with build the intercooler as they need it.
Offline midnightSun
  • Jr. Member
  • Out on bail.
  • Thank You
  • -Given: 5
  • -Received: 3
  • If you can read this you've been passed.
  • Liked:
  • Likes Given: 0
DIRECT PORT so this looks to be injecting meth in all cyls at the sometime?
What is the advantage of this?
In short. Direct port allows you the precisely control how much water methanol is delivered into each cylinder.
These injectors don't seem to be controlled individually. So i'm asking why this is beneficial? It would seem one is using 5x the necessary meth. Soo do you have plans to use Electronic Fuel injection?
"I'm 30 min away, i'll be there in 10"
2016 Explorer Sport 3bar 93 tune.
Continental ZRY summer tires.
I pull a 30' race trailer with this little SUV at times.
2x Regional Champ!
Offline Frozen Blue
  • Full Member
  • Minneapolis, MN
  • Thank You
  • -Given: 22
  • -Received: 20
  • Ecobooster
  • Liked:
  • Likes Given: 0
It ensures even distribution into all cylinders. This way the front cylinders won't receive more than the cylinders at the rear of the intake manifold. Uneven flow may or may not be an issue. We have no idea unless someone tests a transverse 3.5 intake manifold.
2013 SHO non-pp
3 bar Map, 160 tstat
Powerstop Z23 rotors/pads
LMS v10
Offline J-Will
  • Elite Member
  • Thank You
  • -Given: 68
  • -Received: 106
  • Ecobooster
  • Liked:
  • Likes Given: 0
Different size injectors help regulate an even spray. You actually use less meth, the injectors are much smaller
3-bar
SP-542 plugs w/ GH gap
Offline SHOurpp
  • Full Member
  • pa
  • Thank You
  • -Given: 117
  • -Received: 18
  • born again hard
  • Liked:
  • Likes Given: 0
nice tank .not sure where it would fit at
hopefully someone has location pictures or install tips to move that along.
Features Include:
3 Quart
Brass vent
Level sight gauge
Mounting hardware
Special Notes:
duel 3 inch cat less down pipes
sct x4- as a scanner/logger only
3 bar map
hp tuners
both bovs vta
Offline glock-coma
  • Forum Supporter!
  • Elite Member
  • Parma,Ohio
  • Thank You
  • -Given: 661
  • -Received: 699
  • Liked:
  • Likes Given: 0
I'm guessing with the mdesign intake setup there would be enough room next to it to mount this tank. You would just need to fab a bracket.
Offline J-Will
  • Elite Member
  • Thank You
  • -Given: 68
  • -Received: 106
  • Ecobooster
  • Liked:
  • Likes Given: 0
Think the battery is almost 9" tall? Can't mount that tank sideways, the cap has to be on top. Our height requirement is the same as the battery
3-bar
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13036
  • -Received: 4234
  • Liked:
  • Likes Given: 4
The battery is spec'd at 7.63 inches in height
Offline J-Will
  • Elite Member
  • Thank You
  • -Given: 68
  • -Received: 106
  • Ecobooster
  • Liked:
  • Likes Given: 0
So close!  I dont think that tank will work.  I'm all for being wrong though.
3-bar
Offline glock-coma
  • Forum Supporter!
  • Elite Member
  • Parma,Ohio
  • Thank You
  • -Given: 661
  • -Received: 699
  • Liked:
  • Likes Given: 0
From what I remember the bottom of the stock air box sits lower than the battery tray.
Offline hawkeye93
  • Sr. Member
  • Lakeville, MN
  • Thank You
  • -Given: 99
  • -Received: 208
  • Liked:
  • Likes Given: 0
Had a nice phone conversation with Rodney, the owner of ProMeth (formerly Alcohol Injection Systems) today.  Super nice guy, very informative & helpful.  And thanks to Renee for helping with my order.  I ordered a 3 gallon tank for my upcoming meth installation.  Plan to do something similar to the trunk install on Alky's Facebook page.  With meth & AJP's EBC brakes, I'm getting excited for next track season!
2015 Ford Taurus SHO PP 12.219@112.84
LMS catted DP, AirAid CAI, SP-534, Reische 170, 3 bar, hybrid meth system, tunes from Unleashed, Livernois, Brew City Boost & AJP
1965 Ford Mustang Convertible 289 4V/T5Z/3.55
1955 Ford Fairlane Club Sedan 272 4V/Fordomatic
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13036
  • -Received: 4234
  • Liked:
  • Likes Given: 4
Sweet!
* Recent Topics
Re: Brew City Boost no longer to offer tuning.
by TopherSho | February 24, 2021, 08:42:42 PM
There's new rules coming out or out concerning modifications of t...
by bpd1151 | February 24, 2021, 12:22:55 PM
02/24/2021.......Engine builder LMK that internal trans parts have bee...
Re: Converting kPa to PSI?
by Admin | February 22, 2021, 08:08:20 PM
https://www.convertunits.com/from/kPa/to/PSIThis website is great, rem...
Re: RockAuto Wants To Help With Your Upcoming Car Show
by Macgyver | February 19, 2021, 06:34:46 PM
Outstanding Idea !!!...
Re: 2020+ Explorer ST Parts and Tuning Now Available at Ortiz Performance!
by Macgyver | February 19, 2021, 06:33:36 PM
Are you planning or already have the Edge ST ?...
Re: HPTuners Updated Support for 2013-2018 Taurus SHOs
by BOT_ROCKET | February 19, 2021, 05:21:20 PM
No worries on the delay. I totally understand. It got pretty chilly he...
Re: So the tax lady was good to me
by FiveLeeter918 | February 19, 2021, 03:21:46 PM
Hey bud, luckily all of the MKS and SHO stuff is interchangeable. Let ...
Re: &quot;Engine coolant temperature too high&quot;
by ChrisxHowe | February 17, 2021, 01:42:47 PM
Sent from my iPhone using Tapatalk...
2011 Ford Taurus SHO $11,000 Orange Cnty, CA
by dinkydingo | February 16, 2021, 01:18:15 AM
For sale is a 2011 Ford Taurus SHOThe car has had some work done in or...
Re: 2017 Black Ford Edge Sport:
by FoMoCoSHO | February 15, 2021, 03:01:41 PM
unleashedtuning.com and Torrie McPhailIf you really want to go all out...
