Started by Gjkrisa, October 09, 2016, 11:21:48 AM
Quote from: jdsfel on January 22, 2020, 06:44:57 PMHey @Gjkrisa, did you ever get this working? I am planning on buying same kit and was curious if your install went good. Some hints on wire locations would be great also. Thanks, Jerry
Quote from: Gjkrisa on January 22, 2020, 11:26:50 PMQuote from: jdsfel on January 22, 2020, 06:44:57 PMHey @Gjkrisa, did you ever get this working? I am planning on buying same kit and was curious if your install went good. Some hints on wire locations would be great also. Thanks, JerrySorry no I have not. If you'd like I can probably ship you mine I don't think I'll ever have time to install it. Also I feel the back up camera works great just wish I could add sky view in Wich I may upgrade the apim with cameras so I can do that given time. But the newer sync 3 firmware doesn't let you use the Ford GT theme it even been removed from the diagnostic screen so I've read from a good source on Facebook Aftermarket Android radios have been getting better think we maybe close to one for the 2013+ with SkyView but then there's the issue of security updates depending on how much the alter the os. Sent from my Pixel 4 XL using Tapatalk
