2017+ Ford Fusion & Lincoln MKZ
Started by SHOdded, September 16, 2016, 06:49:43 AM
2017 Fusion – Stuck In Park And/or Buzz Noise From Gearshift Module (GSM) – Diagnostic Trouble Code (DTC) P0915 – Built On or Before 9-Aug-2016
Some 2017 Fusion vehicles built on or before 9-Aug-2016 may exhibit DTC P0915 with vehicle stuck in park and/or buzz noise from rotary dial Gearshift Module (GSM).
Address any additional DTCs first. DTC P0915 sets when battery voltage is low at start up.
The root cause of the low battery condition must be identified and corrected.
Refer to Workshop Manual (WSM), Section 414-01.
Reprogram the GSM using Integrated Diagnostic System (IDS) release 103.01 or higher.
Make sure you are connected to the internet while module programming to obtain the latest updates.
Calibration files may also be obtained at www.motorcraftservice.com.
Remove and reinstall fuse #13 from Body Control Module (BCM) to reset the GSM after programming. Clear GSM DTC's.
Module Reprogramming & Initialization
Software necessary to program electronic modules to the latest calibration level, perform module initialization (PATS), and set Programmable Parameters on Ford, Lincoln and Mercury vehicles.
Ford Module Programming (FMP) is a software application that allows subscribers to program electronic modules on Ford, Lincoln and Mercury vehicles. It can be used for:
    Reprogramming emission-related (OBDII) modules on some vehicles manufactured in 1995 and all vehicles manufactured from 1996 to the present
    Reprogramming or reconfiguring non-emission-related modules on many vehicles (UBP and MS-CAN not supported)
In addition, module initialization (PATS) functions such as Keycode Erase/Reprogram and PCM Parameter Reset can be done using this application.
J2534 Device using Ford Module Programming (FMP) can Reprogram and Configure most Modules.
Latest Calibration Information
Module Build Data (As-Built)
Use VIN to obtain As-Built data
2017 MKZ – Interior Courtesy Lamps Flickering – Built On Or Before 1-Sep-2016
Some 2017 MKZ vehicles built on or before 1-Sep-2016 may exhibit the interior courtesy lamps flickering.
Reconfigure the body control module (BCM) using as-built programming.
Make sure you are connected to the internet when entering module programming to obtain the latest data.
2017 Continental/MKZ – 3.0L – AWD – All-Wheel Drive Malfunction Warning Message/Wrench Light – DTC U2008 – Built On Or Before 12-May-2017
Some 2017 Continental/MKZ vehicles equipped with 3.0L engine and all-wheel drive (AWD), built on or before 12-May-2017 may exhibit an all-wheel drive malfunction warning message/wrench light along with DTC U2008 that occurs when using a conveyor type car wash.
Connect the Ford Integrated Diagnostic System (IDS) or equivalent and check the AWD module for DTCs.
If DTC U2008 is stored, then reprogram the AWD module to the latest level using IDS release 106.02 or higher.
Make sure you are connected to the internet when entering module programming to obtain the latest updates.
2017 MKZ – 3.0L – Without Harman Revel Audio System – Interior Cabin Drone Noise – Built On Or Before 23-May-2017
Some 2017 MKZ vehicles equipped with a 3.0L engine and without a Harman Revel audio system and built on or before 23-May-2017 may exhibit an interior cabin drone type noise at 1900-2000 RPMs in 5th or 6th gear.
Reprogram the digital audio control module C (DACMC) to the latest calibration using the Integrated Diagnostic System (IDS) release 106.01 or higher.
TSB 17-0038 Slow Fuel Fill and/or Spit Back During Refueling – 2017 Ford Fusion
This article supersedes TSB 17-0025 to update the production fix date and the Action Statement.
Summary
Some 2017 Fusion vehicles equipped with a 1.5L engine and built on or before 22-Mar-2017 may exhibit a slow fuel fill and/or spit back during refueling. Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 104.04 or higher. Make sure you are connected to the internet when entering module programming to obtain the latest updates. Calibration files may also be obtained at www.motorcraftservice.com.
MAKE           MODEL   YEAR
FORD    FUSION    2017
TECHNICAL SERVICE BULLETIN 17-2235
2.7L/3.0L – Oil Consumption With DTC P0524 And/Or P06DD, Rough Idle, Misfire And/Or White Or Blue Exhaust Smoke – Built On 1-Apr-2016 And Through 1-Jan-2017
17 November 2017
Model:
Ford
2016-2017 Edge
2017 Fusion
Lincoln
2016-2017 MKX
2017 Continental
2017 MKZ
Issue: Some 2016-2017 Edge/MKX, 2017 Continental, and 2017 Fusion/MKZ vehicles equipped with a 2.7L or 3.0L gasoline turbocharged direct injection (GTDI) engine and built on 1-Apr-2016 and through 1-Jan-2017 may exhibit white or blue smoke from the exhaust, rough idle in neutral or park at normal operating temperature or after a hot restart. The vehicle may also exhibit an illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTCs) P0300, P0301, P0302, P0303, P0304, P0305, P0306 and/or P0316, P0524 and/or P06DD with excessive oil consumption. Oil consumption may be 1 Liter (1 quart) in less than 4,800 km (3,000 miles).
Action: Follow the Service Procedure steps to correct the condition.
Parts
Part Number    Description    Quantity
FT4Z-6006-B    2.7L Engine Assembly    1
GB8Z-6006-A    3.0L Engine Assembly    1
FT4Z-6049-E    2.7L Cylinder Head Assembly    1
FT4Z-6049-F    2.7L Cylinder Head Assembly    1
FL3Z-6079-D    2.7L Cylinder Head Gasket Kit    1
GB8Z-6079-A    3.0L Cylinder Head Gasket Kit    1
FT4Z-6675-C    Engine Oil Pan Assembly, 2.7L and 3.0L    1
FT4Z-6731-A    Filter Engine Oil Assembly    1
W712961-S442    Steering Shaft Bolt    1
W712503-S440    Sway Bar Mount Nut    2
W714265-S442    Catalytic Converter Nut    1
BL3Z-9450-A    Catalytic Converter Gasket    2
F2GZ-4682-A    Driveshaft to PTU Bolt and Washer Assembly    3
W790063-S900    Driveshaft to RDU Bolt and Washer Assembly    1
W712154-S439    Center Bearing Bolts    1
W715295-S439    Strut to Knuckle Bolt (package of 4)    1
W520216-S440    Strut to Knuckle Nut (package of 4)    1
W717674-S439    Engine Mount And Bracket Bolt (package of 2)    1
W712334-S442    Engine Mount And Bracket Nut (package of 4)    1
W710807-S442    Engine Mount and Bracket Nut    1
W716779-S439    Transmission Mount Bolt (package of 4)    1
FT4Z-6A340-A    Crank Pulley Bolt    1
FT4Z-9J323-A    High Pressure Fuel Rail    1
CP9Z-6279-C    Variable Camshaft Timing Bolt    1
W716383-S437    Turbo Mounting Stud    1
FT4Z-9J323-B    High Pressure Fuel Rail    1
W520215-S440    Outer Tie Rod End Nut    1
CCPZ-3B477-B    Wheel Hub Nut    1
W500545-S439    Ball Joint Pinch Bolt    1
W520214-S440    Ball Joint Pinch Bolt Nut    1
4S4Z-3N324-AA    Halfshaft Retaining Strap    1
W520102-S442    Halfshaft Retaining Strap Nut (package of 2)    1
W715618-S437    Torque Converter Nut    2
9L8Z-6G004-F    Cylinder Head Temp Sensor Assembly    1
CYFS-092-YPT    Spark Plug SP542    6
CU7Z-19B508-A    Flange Sealant    1
VC-3-B    Motorcraft® Orange Concentrated Antifreeze/Coolant    1
XO-5W30-QSP    Motorcraft® SAE 5W-30 Premium Synthetic Blend Motor    1
ZC-30-A    Motorcraft® Silicone Gasket Remover    1
PM-4-A    Motorcraft® Metal Brake Parts Cleaner    1
ZC-31-B    Motorcraft® Metal Surface Prep Wipes    1
TA-357    Motorcraft® High Performance Engine RTV Silicone    1
TA-24-B    Motorcraft® Thread Sealant With PTFE    1
ZC-37-A    Motorcraft® Wheel And Tire Cleaner    1
XL-2    Motorcraft® High Temperature Nickel Anti-Seize Lubricant    1
W716457-S439    Subframe Bolt (package of 4)    1
7T4Z-1177-C    Right Side Intermediate Shaft Seal Kit (FWD)    1
F2GZ-7H469-B    Right Side Intermediate Shaft Seal Kit (AWD)    1
9W7Z-19B596-A    A/C O-ring Kit    1
DS7Z-19B596-A    A/C O-ring Kit    1
BL3Z-9C995-A    Fuel Injector Clip With O-ring    6
BL3Z-9229-C    Fuel Injector O-ring Kit    2
Warranty Status: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
Description    Operation No.    Time
2017 MKZ FWD 3.0L GTDI: Diagnose And Replace The Long Block Engine Assembly (Can Be Claimed With Operations R Or S) (Do Not Use With Any Labor Operations Outside Of This Article)    172235A    15.1
2017 MKZ AWD 3.0L GTDI: Diagnose And Replace The Long Block Engine Assembly (Can Be Claimed With Operations R Or S) (Do Not Use With Any Labor Operations Outside Of This Article)    172235B    15.6
2017 MKZ AWD 3.0L GTDI: Diagnose And Replace Both Cylinder Head Assemblies (Can Be Claimed With Operations R Or S) (Do Not Use With Any Labor Operations Outside Of This Article)    172235C    20.5
2017 MKZ FWD 3.0L GTDI: Diagnose And Replace Both Cylinder Head Assemblies (Can Be Claimed With Operations R Or S) (Do Not Use With Any Labor Operations Outside Of This Article)    172235D    20.3
2016-2017 MKX/Edge AWD 2.7L GTDI: Diagnose And Replace The Long Block Engine Assembly (Can Be Claimed With Operations R Or S And T) (Do Not Use With Any Labor Operations Outside Of This Article)    172235E    15.7
2016-2017 MKX/Edge AWD 2.7L GTDI: Diagnose And Replace Replace Both Cylinder Head Assemblies (Can Be Claimed With Operations R Or S And T) (Do Not Use With Any Labor Operations Outside Of This Article)    172235F    21
2016-2017 MKX/Edge FWD 2.7L GTDI: Diagnose And Replace The Long Block Engine Assembly (Can Be Claimed With Operations R Or S And T) (Do Not Use With Any Labor Operations Outside Of This Article)    172235G    15.3
2016-2017 MKX/Edge FWD 2.7L GTDI: Diagnose And Replace The Cylinder Head Assemblies (Can Be Claimed With Operations R Or S And T) (Do Not Use With Any Labor Operations Outside Of This Article)    172235H    20.9
2017 Fusion AWD 2.7L GTDI: Diagnose And Replace The Long Block Engine Assembly (Can Be Claimed With Operations R Or S) (Do Not Use With Any Labor Operations Outside Of This Article)    172235J    15.1
2017 Fusion AWD 2.7L GTDI: Diagnose And Replace Both Cylinder Head Assemblies (Can Be Claimed With Operations R Or S) (Do Not Use With Any Labor Operations Outside Of This Article)    172235K    20.1
2017 Continental FWD 2.7L GTDI: Diagnose And Replace The Long Block Engine Assembly (Can Be Claimed With Operations R Or S) (Do Not Use With Any Labor Operations Outside Of This Article)    172235L    14.3
2017 Continental AWD 2.7L GTDI: Diagnose And Replace The Long Block Engine Assembly (Can Be Claimed With Operations R Or S) (Do Not Use With Any Labor Operations Outside Of This Article)    172235M    15
2017 Continental AWD 2.7L GTDI: Diagnose And Replace Both Cylinder Head Assemblies (Can Be Claimed With Operations R Or S) (Do Not Use With Any Labor Operations Outside Of This Article)    172235N    19.9
2017 Continental FWD 2.7L GTDI: Diagnose And Replace Both Cylinder Head Assemblies (Can Be Claimed With Operations R Or S) (Do Not Use With Any Labor Operations Outside Of This Article)    172235O    19.6
2017 Continental AWD 3.0L GTDI: Diagnose And Replace The Long Block Engine Assembly (Can Be Claimed With Operations R Or S) (Do Not Use With Any Labor Operations Outside Of This Article)    172235P    15.5
2017 Continental AWD 3.0L GTDI: Diagnose And Replace Both Cylinder Head Assemblies (Can Be Claimed With Operations R Or S) (Do Not Use With Any Labor Operations Outside Of This Article)    172235Q    20.3
Additional Time To Check And Correct Toe Vehicles Without Lane Departure.    172235R    0.6
Additional Time To Check And Correct Toe Vehicles With Lane Departure.    172235S    0.8
2016-2017 MKX: Additional Time When 360 Degree Camera Alignment Is Necessary.    172235T    0.5
Repair/Claim Coding
Causal Part:    6049
Condition Code:    42
Drive    Tool
1/4″    6 mm Deep Well Socket
1/4″    7 mm Deep Well Socket
1/4″    8 mm Deep Well Socket
1/4″    10 mm Deep Well Socket
1/4″    11 mm Deep Well Socket
1/4″    13 mm Deep Well Socket
1/4″    15 mm Deep Well Socket
1/4″    5 mm Short Socket
1/4″    10 mm Flex Socket
1/4″    10 mm Mid Length Socket
1/4″    13 mm Mid Length Socket
1/4″    15 mm Mid Length Socket
1/4″    1.5″ Extension
1/4″    2″ Extension
1/4″    4″ Extension
1/4″    6″ Extension
1/4″    11″ Extension
1/4″    14″ Extension
1/4″    Long Handle Ratchet
1/4″    Air Ratchet
1/4″    Torque Wrench
3/8″    8 mm Deep Well Socket
3/8″    10 mm Deep Well Socket
3/8″    11 mm Deep Well Socket
3/8″    13 mm Deep Well Socket
3/8″    15 mm Deep Well Socket
3/8″    2″ Extension
3/8″    4″ Extension
3/8″    6″ Extension
3/8″    11″ Extension
3/8″    14″ Extension
3/8″    Long Handle Ratchet
3/8″    6 mm Allen Socket
3/8″    Air Ratchet
3/8″    17 mm Crows Foot
3/8″    15 mm 12-Point Deep Well Socket
3/8″    E8 Torx Socket
1/2″    13 mm Deep Well Impact Socket
1/2″    15 mm Deep Well Impact Socket
1/2″    18 mm Deep Well Impact Socket
1/2″    21 mm Deep Well Impact Socket
1/2″    32 mm Deep Well Impact Socket
1/2″    24 mm Short Socket
1/2″    Long Handle Ratchet
1/2″    Impact Wrench
1/2″    Torque Wrench
1/2″    Long Breaker Bar
   10 mm Combination Wrench
   13 mm Combination Wrench
   15 mm Combination Wrench
   17 mm Combination Wrench
   18 mm Combination Wrench
   19 mm Combination Wrench
   7 mm Ratchet Wrench
   8 mm Ratchet Wrench
   10 mm Ratchet Wrench
   13 mm Ratchet Wrench
   15 mm Ratchet Wrench
   18 mm Ratchet Wrench
   Small Trim Tool
   Large Trim Tool
   Hose Clamp Pliers
   Pliers
   Long Pry Bar
   17″ Punch
   20 Ounce Hammer
   Steering Wheel Tool
   Magnet
   Bungee Cords
   Seal Pick
   Marker
   2″ Roloc Disc
   1/2″ Drill
   Plastic Scraper
   Air Blow Gun
   Phillips Screwdriver
   Engine Spreader Bar 303-1246
   Lift Eyes 313-1634
   Torque Converter Retainer 307-346
   Disconnect Tool 307-569
   Installer Halfshaft 204-161
   Front Wheel Hub Remover 205D070
Service Procedure
1. Check the vehicle build date. Was the vehicle built on 1-Apr-2016 and through 1-Jan-2017?
(1). Yes – proceed to Step 2.
(2). No – this article does not apply. Refer to the Powertrain Controls/Emissions Diagnosis (PC/ED) manual for normal diagnostics.
2. Connect the Ford Integrated Diagnostic System (IDS) or Ford J2534 Diagnostic Software (FJDS) to the data link connector (DLC) and check for DTCs. Are DTCs P0524 and/or P06DD stored in the powertrain control module (PCM) memory?
(1). Yes – continue to Step 3.
(2). No – replace the cylinder heads. Refer to Workshop Manual (WSM), Section 303-01. The repair is complete.
3. Check the engine oil level on the engine oil level indicator. Refer to WSM, Section 303-01. Is the oil level within the minimum and maximum marks on the indicator?
(1). Yes – proceed to Step 4.
(2). No – add engine oil as needed to achieve the correct oil level on the indicator. Proceed to Step 4.
4. Run the engine until it reaches normal operating temperature. Using IDS or FJDS monitor the engine oil pressure. Refer to WSM, Section 303-01. Is the oil pressure within specification?
(1). Yes – replace the cylinder heads. Refer to WSM, Section 303-01.
(2). No – replace the long block engine assembly. Refer to WSM, Section 303-01.
Prior approval and cost cap must be completed as required; however, follow the diagnostics repair procedure in this article to determine correct repair.
SSM 47083 – 2017-2018 MKZ – Steering Wheel Does Not Move To The Full Up Position When Entering Or Exiting The Vehicle – Built On Or Before 10-Oct-2017
Some 2017-2018 MKZ vehicle built on or before 10-Oct-2017 may exhibit a steering wheel that does not travel to the full up position when the easy entry/exit feature is enabled.
Reprogram the DSM using Integrated Diagnostic System (IDS) or Ford J2534 Diagnostic Software (FJDS) release 108.03 or higher.
Perform a driverseat module (DSM) reset. Select Toolbox ⇒ Body ⇒ Service Functions ⇒ DSM Reset.
Next, program the DSM using as-built.
For claiming, use causal part 14C708 and applicable labor operations in section 10 of the service labor time standards (SLTS) manual.
SSM 47285 – 2018 Fusion 2.0L GTDI and 1.5L GTDI – Delete Engine Beauty Cover
Some 2018 Ford Fusion vehicles, the engine beauty cover was deleted as a running change.
If during PDI a unit is reported as received without engine beauty cover from factory, the unit was built correctly.
Any repair or the addition of this part would not be considered warrantable.
APPLICABLE VEHICLES
2018 CAR: C7 CD391N FUSION
TSB 18-2025:  Driver's Power Seat Function Inoperative – 2017 Ford Fusion & Lincoln MKZ
Issue: Some 2017 Fusion/MKZ vehicles built on or before 12-Jun-2017 may exhibit a driver's power seat function that is inoperative with or without fuse F74 open.
Parts
NAI837X    Coroplast Electrical Wire Harness Tape    1
Labor Times
2017 Fusion/MKZ: Visually Inspect And Repair Wire Harness Includes Time To Remove And Install Seat (Do Not Use With Any Other Labor Operations)    182025A    0.8
Repair/Claim Coding
Causal Part:    14D231
Condition Code:    30
Drive    Tool Name
3/8″    Power Tool
3/8″    Ratchet
3/8″    Torque Wrench
3/8″    Torx® Socket T50
3/8″    Torx® Socket T55
   Trim Tool
   Push Pin Tool
   Soldering Gun
   Heat Gun
Service Procedure
1. Check the vehicle build date. Was the vehicle built on or before 12-Jun-2017?
2. Visually inspect the seat wiring harness by looking from the front, under the driver's seat. When looking from the front under the seat the chafe point is located on the left side and is rubbing on the seat adjustment framing. Is there chafing to the wire harness? (Figures 1 – 2)
(1). Yes – proceed to Step 3.
(2). No – this article does not apply. Refer to Workshop Manual (WSM), Section 501-10.
Figure 1
seat wiring harness
Figure 2
seat wiring harness
3. Remove the seat. Refer to WSM, Section 501-10.
4. Repair the wire concern. Refer to cell 5 in the Wiring Diagram (WD). The wire harness should also be wrapped with Coroplast wire harness tape or equivalent available from the Rotunda Technician Tool Program (RTTP).
5. Relocate the wire harness clip from the seat frame and attached it to the track sinuous wire. (Figures 3 – 4)
Figure 3
Figure 4
6. Reinstall the seat. Refer to WSM, Section 501-10.
SSM 47281 – 2013-2018 C-MAX, Fusion/MKZ Hybrid/Energi – Possible Water Intrusion In Multiple Connectors
Some 2013-2018 C-MAX/Fusion/MKZ Hybrid/Energi vehicles may exhibit various drivability or electrical concerns accompanied by one or more diagnostic trouble codes, with the most common being P26C3, P26CA, P26D0, P2800, P2802, U019F and U0284.
On C-MAX inspect connectors C134, C140, C144, C1651, C1717 and C1812 for signs of water entry/corrosion and service as necessary.
On Fusion/MKZ inspect connectors C146, C1651, C1812, C168C and C134 and service as necessary.
APPLICABLE VEHICLES
2013 – 2018 CAR: C7 CD391N FUSION
2013 – 2018 CAR: C9 CD533N MKZ
2013 – 2018 CAR: CG C344N C-MAX
