Ford Explorer
Started by SHOdded, September 15, 2016, 07:02:58 AM
2017 Explorer/Taurus/Police – 3.5L or 3.7L TiVCT Engine – Illuminated MIL – DTC P0740 or P0743 – Built On 14-Jun-2017 And Through 21-Jun-2017
Some 2017 Explorer/Taurus/Police vehicles equipped with a 3.5L or 3.7L twin independent variable camshaft timing (TiVCT) engine, built on 14-Jun-2017 and through 21-Jun-2017, may exhibit an illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTCs) P0740 or P0743 stored in powertrain control module (PCM) memory.
Prior to replacing any components, check pin 14 in connecter c168 for correct fitment, tension, push out, or any signs of damage.
If terminal replacement is necessary, pigtail kit 8U2Z-14S411-ACB can be ordered to obtain the terminal with wire lead.
If no concerns are found with C168, follow normal diagnostic routines for the fault codes.
FORD RECALLS 202,000 EXPLORER SUVS AND F-150 TRUCKS
DECEMBER 1, 2017Ford is recalling more than 202,000 model year 2016 Ford Explorer SUVs The recalled 2016 Ford F-150 trucks were built in Michigan and Kansas City between January 22, 2016, and April 19, 2016, and the recalled 2016 Ford Explorers were built in Chicago during the same time period.
Ford dealers will handle the recall repairs in two ways. Dealers will measure the torque of the power seat pivot link bolt and if the bolt passes inspection, dealers will remove and clean the bolt, apply new threadlock and reinstall the bolt using the correct torque.
However, if the bolt fails inspection, Ford technicians will apply new threadlock and the bolt will be reinstalled as an interim repair until the final repair is available. The final repair will have dealers replacing the lift links with new bushings and fasteners.
Owners of 2016 Ford Explorer SUVs and Ford F-150 trucks may contact Ford at 866-436-7332 and use reference number 17S40
Ford F-150 trucks because the front power seat cushions can loosen and cause problems in a crash.
About 177,000 of the recalled vehicles are in the U.S., another 22,620 are in Canada and nearly 2,400 are recalled in Mexico.
Ford says upper left-hand pivot bolts can loosen and fall out of the front power seat adjusters, leaving the front seat cushions to move around in a crash. However, the automaker says it's unaware of any crashes or injuries related to the loose pivot bolts.
The recalled 2016 Ford F-150 trucks were built in Michigan and Kansas City between January 22, 2016, and April 19, 2016, and the recalled 2016 Ford Explorers were built in Chicago during the same time perioiod.
   http://m.carcomplaints.com/news/2017/ford-recalls-explorer-suvs-f-150-trucks.shtml
SSM 46905 – 2015-2018 – Explorer – Hankook Brand Tire – Chipping, Cutting And/Or Unusual/Accelerated Tread Wear
Some 2015-2018 Explorer vehicles equipped with Hankook brand tires may exhibit chipping, cutting and/or unusual or even accelerated tread wear.
If the tire side wall is marked as: 255/50R20 105H Ventus S1 Noble 2 contact Hankook Technical Service for possible pro-rated tire replacement.
This may not be the result of improper alignment.
For Hankook contact information refer to the Tire Warranty information located on FMCDealer.com.
APPLICABLE VEHICLES
2015 – 2018 TRUCK: UB EXPLORER
SSM 46888 – 2017 Explorer – 110V Power Inverter – High Pitched Buzzing/Ringing Noise With Engine Running From Passenger Side Front Interior
Some 2017 Explorer vehicles equipped with a 110V power inverter may exhibit a high pitched buzzing or ringing noise from the passenger side front interior area while the engine is running.
To isolate the noise to the power inverter, remove fuse 56 from the battery junction box with the engine running.
Make sure there is nothing plugged into the 110V outlet during the test.
If the noise is no longer present with the fuse removed, the noise is isolated to the inverter and no other components should be replaced.
Replacement of the inverter may not resolve the noise.
Engineering is aware of the concern and is investigating.
The noise does not affect the operation of the power inverter.
Please submit a Global Concern Report and continue to monitor OASIS for updates.
APPLICABLE VEHICLES
2017 TRUCK: UB EXPLORER
2017 Explorer/Taurus/Police Interceptor – Fixed Brake Pedal – Brake Drag – Built On 19-May-2017 And Through 30-May-2017
Some 2017 Explorer, Taurus, Police Interceptor vehicles built on 19-May-2017 and through 30-May-2017 equipped with a fixed brake pedal assembly may exhibit a brake drag concern or residual pressure in the brake system with the brake pedal fully released.
This may be due to an interference condition between the brake pedal arm stop lamp switch bracket and the booster push rod clevis pin bracket.
Inspect for a touch condition between the brake pedal arm stop lamp switch bracket and the brake booster push rod clevis pin bracket.
If a touch condition exists, replace the brake pedal assembly.
Recall 17S23 – Electronic Power Assist Steering Heat Shield Fastener Inspection – 2017 Ford Explorer & Taurus/Police Interceptor
https://www.ecoboostperformanceforum.com/index.php/topic,3836.msg131071.html#msg131071
TSB 17-0033    2.3L ENGINE – IDLE SPEED DROPPING BELOW SPECIFICATION – BUILT ON OR BEFORE 28-FEB-2017
Publication Date: March 21, 2017
FORD:    2016-2017 Explorer
ISSUE:
Some 2016-2017 Explorer vehicles equipped with a 2.3L engine and built on or before 28-Feb-2017 may exhibit the idle speed dropping below specification after repeated light pedal tip-in/tip-out events at low vehicle speeds, such as in heavy traffic jams or a parking lot maneuvers.
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 104.04 or higher. Make sure you are connected to the internet when entering module programming to obtain the latest updates. Calibration files may also be obtained at www.motorcraftservice.com.
NOTE: ADVISE THE CUSTOMER THAT THIS VEHICLE IS EQUIPPED WITH AN ADAPTIVE TRANSMISSION SHIFT STRATEGY WHICH ALLOWS THE VEHICLE'S COMPUTER TO LEARN THE TRANSMISSION'S UNIQUE PARAMETERS AND IMPROVE SHIFT QUALITY. WHEN THE ADAPTIVE STRATEGY IS RESET, THE COMPUTER WILL BEGIN A RE-LEARNING PROCESS. THIS RE-LEARNING PROCESS MAY RESULT IN FIRMER THAN NORMAL UPSHIFTS AND DOWNSHIFTS FOR SEVERAL DAYS.
OPERATION    DESCRIPTION    TIME
170033A    2016-2017 Explorer 2.3L: Reprogram The PCM (Do Not Use With Any Other Labor Operations)            0.3 Hr.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO.    CONDITION CODE
RECAL    04
April 12, 2017 MANUFACTURER COMMUNICATION NUMBER: SSM 46522
Summary
2013-2017 Edge/MKX/Flex/MKT/MKZ/MKS/Taurus/Taurus Police/Explorer/Explorer Police/Continental vehicles equipped with a 3.5L or 3.7L engine, all wheel drive (AWD) and a power transfer unit (PTU) that is being repaired or replaced for an internal failure must also have the vent hose replaced due to contamination in the hose.
2015-2016 Edge/MKX And 2013-2016 Explorer/Taurus – Automatic Transmission Fluid Leaking From The PTU Temperature Sensor
Some 2015-2016 Edge/MKX and 2013-2016 Explorer/Taurus vehicles may exhibit a condition where automatic transmission fluid (ATF) may appear to be leaking from the power transfer unit (PTU) temperature sensor.
ATF in the area of the PTU temperature sensor may be the result of a leaking right hand (RH) intermediate shaft seal deflector.
Replacement of the PTU temperature sensor will not resolve this condition.
To correct the condition replace the RH intermediate shaft seal.
Refer to Workshop Manual, Section 308-07.
2013-2017 Multiple Vehicles – 3.5L or 3.7L – AWD – PTU Vent Hose Replacement Required After PTU Internal Repairs Or Replacement
2013-2016 Explorer/Taurus/Police Interceptor – All Wheel Drive (AWD)- PTU Cooler Service Part Kit Available
Some 2013-2016 Taurus/Explorer/Police Interceptor AWD vehicles equipped with a power transfer unit (PTU) cooler can now have repairs made to the PTU cooler without replacing the PTU assembly.
Order PTU cooler kit DG1Z-7K177-A for PTU cooler repairs.
Part Number    Part Description
DG1Z-7K177-A    PTU Cooler Kit
The kit contains the cooler, gasket, fasteners, and instruction sheet.
Refer to transfer case cooler in the Workshop Manual (WSM), Section 308-07 for the removal and installation procedure.
The parts catalog update is in process.
SSM 47393 – 2016-2018 Explorer – Air Conditioning (A/C) Defaults To Heat And Defrost During Remote Start
Some 2016-2018 Explorer vehicles may automatically switch from A/C to heat and defrost after 1 minute during a remote start idle when the customer expects the A/C remain on. The system will return to normal operation after the ignition is turned to the run position.
Do not attempt any repairs at this time.
Engineering is investigating, monitor OASIS for updates.
To assist with the investigation, use the Report A Vehicle Concern link at the bottom of the OASIS report to complete the form.
APPLICABLE VEHICLES
2016 – 2018 TRUCK: UB U502N EXPLORER
SSM 47348 – 2013-2018 Police Interceptor Utility – 3.7L TiVCT – Engine Vibration And/Or Engine Mount Leaking
Some 2013-2018 Police Interceptor Utility vehicles equipped with a 3.7L twin independent variable camshaft timing (TiVCT) engine may exhibit an engine vibration and/or the engine mount leaking fluid.
A revised engine mount (GB5Z-6038-A) has been released to address this condition.
For claiming, use causal part 6038 and applicable labor operations in Section 06 of the Service Labor Time Standards (SLTS) Manual.
APPLICABLE VEHICLES
2013 – 2018 TRUCK: UB U502N EXPLORER
SSM 47411 – 2018 Explorer – "Hill Descent Control Fault" Message In Instrument Panel Cluster (IPC) Without DTCs – Built On 25-Oct-2017 And Through 01-May-2018
Some 2018 Explorers equipped with Platinum trim level built on 25-Oct-2017 and through 01-May-2018 may intermittently display a "Hill Descent Control Fault" message in the IPC briefly at start up without any diagnostic trouble codes (DTCs) stored in the anti-lock brake system (ABS) module.
Reprogram the IPC using the appropriate Ford scan tool or equivalent release 110.03 or higher.
For claiming, use causal part 10849 and applicable labor operations in Section 10 of the Service Labor Time Standards (SLTS) Manual.
APPLICABLE VEHICLES
Service Information & Reprogramming
Module Reprogramming
Diagnostic Software    Interface Device    Complete Vehicle Diagnostics    Module Programming
1996-2017
Model Year    2018-Present
Model Year    1996-2017
Model Year
IDS/FDRS    VCM, VCM II, VCMM    X    X    X    X
FJDS/FDRS    Compatible J2534 Devices
(Including VCM II and VCMM)       X    X    X
Detailed system requirements, installation, and support information for each product is located under the diagnostics tool support tab for each product.
Integrated Diagnostic Software (IDS) / Ford Diagnosis & Repair System (FDRS)
For use with VCM I, VCM II, VMM and VCMM hardware devices only. The complete factory Ford Motor Company vehicle diagnostic tool that provides complete dealership level vehicle diagnostic coverage for all 1996 to present Ford, Lincoln and Mercury vehicles. The IDS software includes time based access to the IDS software, software updates and calibration files.
Ford J2534 Diagnostic Software (FJDS) / Ford Diagnosis & Repair System (FDRS)
For use with compatible J2534 hardware devices. FJDS software provides Ford Module Programming functionality that covers 1996 to present Ford, Lincoln and Mercury module reprogramming functions, plus complete dealership level vehicle diagnostic software for all 2018 to present Ford and Lincoln vehicles. The FJDS software license includes time based access to the FJDS software, software updates and calibration files.
Latest Calibration Information
Module Build Data (As-Built)
Use VIN to obtain As-Built data
SSM 47330 – 2013-2015 Explorer – Steering Wheel Oscillation/Vibration At Idle
Some 2013-2015 Explorer vehicles may exhibit a steering wheel oscillation/vibration at idle with the vehicle in gear, brake applied, and the drivers hands are off of the steering wheel after a door is slammed shut.
To resolve the concern, reprogram the power steering control module (PSCM) using the appropriate Ford scan tool or equivalent release 109.05 or higher.
For claiming, use causal part 3504 and applicable labor operations in Section 03 of the Service Labor Time Standards (SLTS) Manual.
APPLICABLE VEHICLES
2013 – 2015 TRUCK: UB U502N EXPLORER
