Quote from: FearlessAZ on September 07, 2016, 11:49:58 AM
Only problem I have ever had with my TB is interior is a little cheap. But so are most vehicles around that time. She runs good and strong and has always been reliable (except when my transmission pump went out at 170k miles).
Congrats on the new F150! I have driven a bunch of those for work and always liked them.
I've never been impressed with Chevy's truck interiors. We had a 1991 S10 Blazer where literally every single plastic component would break when moved, including the arm rest. First thing that went out in the Trailblazer was the armrest. Then the center console broke off the bracket, and the 4WD switch broke.
The horn failed due to corrosion on the contacts behind the airbag, the gear controlling the HVAC vents in the rear failed, but I couldn't repair it because I'd have to drain and cap the rear evaporator and heater core, the blower control failed, the idler pulley seized up on our trip to Arizona in 2011 leaving us stranded 30 miles south of Burley, ID until AAA picked us up, the vacuum controller for the gas tank failed, as well as the gas cap itself and finally the transmission stopped shifting into third or OD. I got that fixed and then two months later we got rear-ended and that was that.
Hopefully we have better luck with the F150.
