Rough idle, shaking when in d and taking foot off brake.
Started by polskifacet, May 30, 2016, 01:57:39 PM
I'd say give it a good 1,000 miles first to break it in and look for issues.
Spenser281
This all came from a rough idle?!!!
Sent from my SAMSUNG-SM-G900A using Tapatalk
2010 SHO
Work in progress....
FaSSt9602
That is pretty much my story to a T.  Took it in because it would shake off idle.  After a few weeks of changing the whole PCV system, spark plugs, etc, they did a compression test and found a dead cylinder.  Upon tear down they found a cracked ring land.  Piston ring was wedge in a compressed state causing the excess blowby and loss in compression.  New short block fixed that issue.
Two years later I'm fighting another issue though!
2010 EB Flex Limited Dark Ink Blue Metallic/White Suede two tone
Sadly it is the wife's car, so I can't go too crazy on it...just a simple tune for now.
Spenser281
#48
I'm having this exact same issue.  Exactly.  No misfire codes.  No check engine lights at all.  No noticeable issues anywhere but idle.  Just had my brother follow behind me to see if there was any smoke.  No smoke other than the typical GDI smoke.  I DO have an oil residue all over the back bumper and there IS oil all over and around the rear turbo and some around the front turbo.  Would the leaking oil around the turbos cause a rough idle?
2010 SHO
66 Galaxie
Check your spark plugs for signs of running rich or burning oil.
If you suspect blow bye at idle pull the dipstick and look for any puffs of oil vapor.
polskifacet
my turbos were also visibly leaking. Probably from the blow by/excess crank case pressure.
paokara777
Just a question, how obvious was it (the shake/vibration)
Was it subtle, or was it very noticeable - like even a passenger that knows nothing about cars would notice it easily even first time being it the car?
Daily Drive:
2010 Ford Taurus SHO, AJP 3BAR 93, K&N drop in
Weekend Cruiser:
1968 Ford Mustang Coupe 289 C Code
4Bl Carb, HiPo Cam, Headers and Exhaust
polskifacet
enough to shake my body in the car. it also happened instantly, no signs coming up to the failure
paokara777
It's the scary truths about performance (especially turbo) cars. We are putting an engine through much more than a naturally aspirated engine.
Daily Drive:
Weekend Cruiser:
