Quote from: clubsfit on September 09, 2016, 10:32:19 AM
Well it is starting to get cooler, and I monitor fuel pressure real time on my DD tune, and it does drop off after the 2-3 shift for sure. I am open to ideas on how to fix that?
Welcome to the brick wall of running out of fuel when you don't control the boost spikes..
I had a similar issue but AJPTurbo helped me get back on track by controlling the boost spikes..
According to LME they only raise only a couple lbs over stock which is around 8-10psi... although I have heard rumors of 93v10 pushing 14.5psi - 15psi...and I am sure they doing something to control boost spikes...
I have seen Unleashed logs pushing similar boost although not that timing without Meth and the fueling pressure takes a massive dive..
So all in all, what your seeing if pretty typical...
I think I saw your tune was targeting 216kpa which is 16.82psi which is a lot of boost and you are spiking at 22.33psi on the shift into 3rd gear.. and then to a hair over 21psi in the shift to 4th... those types of boost spikes are going to punish your fuel rail.. I suspect that having your Lambse set to .82 or 12.05 AFR is helping your fuel pressure recover in between boost spikes since you are not running super rich...
Honestly with that big dip in third gearand the fact that you need to mix in 100 Octane or mix Ethanol to keep the knock down, I would be surprised if there is much room to run that tune any hotter safely to get better times unless you reign in those boost spikes..but I am not a tuner so take what I have to say at face value...
