K&N vs OEM air filter testing
Started by FoMoCoSHO, August 29, 2016, 01:03:46 AM
slurppie
I found an article where they used Green filters on the EB for the Daytona testing/race. Granted they probably tore the engine down after the checkered flag but i hope there was some good reason they chose that filter (other than Green offering $$$ for Ford to use them).
sent from my speak n' spell using tin cans and string
2013 w/PP
Synthetic blinker fluid
Ceramic muffler bearings
paokara777
According to this, Green filters flow better than K&Ns ?
Did they sabotage this test xD
https://www.youtube.com/watch?v=cY7fSPvI8bY
Daily Drive:
2010 Ford Taurus SHO, AJP 3BAR 93, K&N drop in
Weekend Cruiser:
1968 Ford Mustang Coupe 289 C Code
4Bl Carb, HiPo Cam, Headers and Exhaust
slurppie
#17
K&N and Green comparison,
Not sure why my images are reversed but the Green filter is the thicker one in the middle picture.
2013 w/PP
They appear to have a very similar number of pleats.  Thickness is about 25% more for the Green?
slurppie
Sounds about right. I can measure tomorrow if need be. I think the K&N has more pleats per inch where as the Green has larger pleats so its probably a wash on total surface area.
2013 w/PP
http://www.greenfilterusa.com/features-and-benefits.php
Deep pleats in the double-layered cotton create a 10-15% increase in filtration surface. This increase allows a greater volume of air to move more freely into your engine cylinders while maintaining superior filtration. Our specially designed cotton filter traps particles as small as 5 microns."
Besides the 5 micron claim I really don't see much info about the filters most important job, filtration.
I don't understand the clams of higher flow with better fuel economy. If I have more air at any given throttle position the ECM is going to add fuel to hit my AFR target. Right? Or am I missing something?
r2c performance...still reading about their tech but this is looking like a possible option. If it filters as well as they claim this would pair well with an Mdesign intake. I wonder if they will sell it with a no filter option?
http://www.r2cperformance.com/black-hex-series-conical-filters.aspx
http://www.r2cperformance.com/technology/r2c_filter_technology.aspx
Another very promising option would be the Donaldson Powercore but that would require a custom mounting solution.
http://www.donaldsonoemfiltration.com/library/files/documents/pdfs/059806.pdf
paokara777
"f I have more air at any given throttle position the ECM is going to add fuel to hit my AFR target. Right? Or am I missing something?"
I think you're right to a certain extent, i think the school of thought is, more air = more power, which means you need less throttle to get the same cruising speed which lowers MPG.
My cousin, who builds old carb chev engines once told me - Gasoline doesn't make the power, the AIR does.
Having said that, you are correct, wouldn't more air mean the ECM would need to adjust to add more fuel? So we are back at square 1 with power / economy
Daily Drive:
Weekend Cruiser:
Fuel economy would be affected by trans gear ratios and engine speeds required to achieve any given power level, I'd think.  The PCM does need to understand the airflow range it can expect to enter the system though, to be able to cope with the fueling needs.
slurppie
Hiflow, hi filtration blah blah blah. Found a compromise, just need someone to fab an airbox.
2013 w/PP
AnotherGreenFusion
'15 Fusion SE 2.0 AWD
CP-E Cold Side, Hot Side, αIntake, QKspl DP & RMM | Boomba Can | Cordova TB | Synapse Gen III BOV | Levels FMIC | 160* T-Stat | Steeda STB, Sway | Flatout 5700 | SCT by Unleashed/LMS 93v11
PM me for AMSOil @ Cost
Gjkrisa
Quote from: FoMoCoSHO on August 30, 2016, 10:47:15 PM
Engine load will be lower getting better gas mileage
Gjkrisa
Quote from: AnotherGreenFusion on August 31, 2016, 06:26:00 PM
Here you go 1000CFM rated
http://hydrobuilder.com/intake-filter-10-x-16-1000-cfm.html?utm_source=google&utm_medium=shopping&utm_campaign=701285&gclid=Cj0KEQjwgJq-BRCFqcLW8_DU9agBEiQAz8KohzdvFOf6CE1I08oIr4QdL3_6UMFf1L0AQ0N_2NseSHoaAh8C8P8HAQ
Just need to look toward industrial applications and then build a massive hood scoop.
Sounds great to me
Quote from: FoMoCoSHO on August 30, 2016, 11:00:02 PM
metroplex
The OP's link is from the Arlen Spicer test, which I believe was done in 2004 or earlier. The Amsoil used in that test no longer exists in that configuration and has been improved almost a decade ago IIRC... It's still a good read.
The K&N looks to have 40 pleats, while the Green has 35 pleats if I counted correctly. But the Green filter looks like someone who was drunk put it together. The pleats are all misaligned with splotches of polyurethane on some of the pleats, and I can see some mesh being exposed as well. I'm not saying K&N is always great, I've had to return a K&N because there was a hole in the polyurethane that would allow dirt to bypass the cotton.
If you want to see a really thick aftermarket filter, look at the AEM Dry Flow. They make one for the Duratec/SHO. I bought one for my GM LNF stock airbox but it was so thick to the point it was more restrictive than the factory filter (which is unique in its design) because it was so thick and extended too low in the box.
How well does the K&N seal in the stock SHO airbox? I've read reviews complaining about it being too thick/tight, and then some reviews say it goes in smoothly. Any long-term results with the Green filter? How good is it?
Previously: 2014 SHO
12.4 @ 110.9 mph
Current: 2017 Fusion Sport
paokara777
I recently purchased a K&N filter and it fit pretty good
Daily Drive:
Weekend Cruiser:
