Started by sholxgt, August 23, 2016, 07:13:11 PM
Quote from: ZSHO on September 18, 2016, 08:12:56 AMThis am after driving for roughly 15 min to get some coffee came home to grab my 10mm socket,Ratchet to inspect the module a bit further noticed it was a bit warm to the touch on a 60 degree morning with very limited driving on a full tank of gas......just makes you wonder the effect's if the conditions were greater.....wonder if installing some heat resistant tape on the metal might help to alleviate these conditions a tit. Z
Quote from: CroR1 on September 18, 2016, 09:13:08 AMQuote from: ZSHO on September 18, 2016, 08:12:56 AMThis am after driving for roughly 15 min to get some coffee came home to grab my 10mm socket,Ratchet to inspect the module a bit further noticed it was a bit warm to the touch on a 60 degree morning with very limited driving on a full tank of gas......just makes you wonder the effect's if the conditions were greater.....wonder if installing some heat resistant tape on the metal might help to alleviate these conditions a tit. Z That would not be a bad idea. Too much heat or cold is an issue with just about anything electrical
Quote from: SHOdded on September 18, 2016, 05:39:10 PMIf Z has to get his FPCM replaced, maybe he can convince the SA to dissect the old part
