Started by StealBlueSho, August 07, 2016, 07:22:28 AM
Quote from: FoMoCoSHO on August 07, 2016, 11:49:14 PMQuote from: StealBlueSho on August 07, 2016, 11:40:29 PMYou can not do separate logs. The easiest way is to just log the entire time then use the "Save View" option in LiveLink II on the runs you want separated out.Sent from my Nexus 6P using TapatalkAny idea how long before memory runs out?
Quote from: FistyMcgee on August 11, 2016, 07:38:31 PMShould I datalog and send the data to LMS to refine the tune that they sent me then? That's what I understand from this conversation. I don't mind sounding stupid so I ask questions like this.
Quote from: SHOdded on August 08, 2016, 11:14:54 AMHow many PIDs, AGF?
Quote from: FistyMcgee on August 15, 2016, 03:51:12 PMGot it, I'll need sct x4 so I know what's going in with the car in general.
Quote from: FoMoCoSHO on August 16, 2016, 10:33:54 PMFYI for anyone doing this, my device updater would not transfer the file....ended up that it didn't like Livelink and the updater open at the same time. When I closed both and reopened the updater it worked perfectly.
Quote from: StealBlueSho on August 16, 2016, 10:35:06 PMQuote from: FoMoCoSHO on August 16, 2016, 10:33:54 PMFYI for anyone doing this, my device updater would not transfer the file....ended up that it didn't like Livelink and the updater open at the same time. When I closed both and reopened the updater it worked perfectly.Good point... Forgot about that.. thanks for catching it!Sent from my Nexus 6P using Tapatalk
Quote from: FoMoCoSHO on August 16, 2016, 10:41:22 PMQuote from: StealBlueSho on August 16, 2016, 10:35:06 PMQuote from: FoMoCoSHO on August 16, 2016, 10:33:54 PMFYI for anyone doing this, my device updater would not transfer the file....ended up that it didn't like Livelink and the updater open at the same time. When I closed both and reopened the updater it worked perfectly.Good point... Forgot about that.. thanks for catching it!Sent from my Nexus 6P using TapatalkYou work with SCT long enough you learn to understand its "quirks" when it decides not to behave, lol.
Quote from: StealBlueSho on August 19, 2016, 10:52:28 AMQuote from: SHOdded on August 08, 2016, 11:14:54 AMHow many PIDs, AGF?I get about 26 minutes to logging with 37 pids and one OBD...longer if I cut out some of the pids...
