Can you add RPM to your graph?
Forscan works well and I think is giving you a pretty accurate picture of what is occurring real time. What it can't tell you is if which tables/adders/compensations are in play. I have the luxury of a tuner that can tell me all those things. I think you had power left on the table and when you run in improved conditions I'd bet it will be a 13.3-13.7 car. Mine ran 13.48 stock with a little E85. Fall can't get here soon enough.
On the SHO there are 3 sensors, IAT1, CAC, IAT2, and the air temp compensation is based off of IAT2. So temp reading at airbox, CAC outlet, and intake.
Looking at my track log my IAT2 fail starts at 160, drops to 151 (no help) and then starts to climb again from the 2-3 downshift to a max of 172 at the end of pull 1. I don't think the track design helps and traps hot dirty air, as soon as I pull around the wall IAT2 drops.
CHT starts low 200's and builds to 260 at the end. I'm curious if the difference is something hardware related or Quantum Blue coolant helping out or both. I have some sitting in the garage I should probably use.
Looks like you started at 110 so maybe your intercooler will be more effective than ours. That would be super helpful since you mentioned your desire to avoid meth. I share that hence my frustration with our IC and lack of aftermarket support.
If you want to look at other logs to compare what is going on, you could always download livelink from SCT. Some of us post up our logs we take for our tuners and at the track.
https://www.sctflash.com/support
