That is one of the strangest logs I have seen.....There is an element of time involved....Like timers for the torque limits maybe...Ask torrie how the LAMBSE is coming down in a linear fashion as the pull goes on.....It's coming down independent of RPM , gear and load, I've never seen that and would have no idea how to do it.....Just guessing here but I'm thinking he is doing that in an attempt to correct the fueling for meth addition...Since I've not seen good logs with meth in terms of fueling
The car is over fueling because it doesn't know where the meth is coming from so stft's plummet and you reach the max amount allowed to be pulled
So you are commanding a leaner mix early in the pull and that may slightly help with trims which are about .85ish then as the pull goes on you command a richer mix so the car dumps more fuel plus your meth then the trims go to .75ish.
Something gets unhappy eventually and boost is dumped
It's really weird
You can get away with commanding .90 Lambda because in reality you will be richer than that because of the meth you are dumping and it will stay rich because you are dumping more meth than the ECU can compensate for to maintain lambda by removing fuel via STFT
