Downpipe Install
Started by sholxgt, July 23, 2016, 09:31:45 PM
StealBlueSho
I'm used to the softer partial metal partial organic gaskets that need to be replaced after every use... You think reusing the layered metal ones are not asking for a exhaust leak later on? Did they look that good?
sholxgt
Quote from: StealBlueSho on July 27, 2016, 08:42:30 AM
I could not see a visual difference between my original/used gaskets and the new ones I purchased.  For peace of mind, I replaced the top ones figuring that those would be the hardest to change later.
I kept the originals because I would not hesitate to reuse them if needed.  About the only reason I could see to purchase gaskets would be to have them as back up in case you mangle the originals.
10bird
How long should this install take for a shop to do?
derfdog15
Quote from: 10bird on March 31, 2017, 10:51:50 AM
3 hours MAXIMUM, especially since they should be using a lift.
My initial install took ~2.5 in a driveway, hardest part was getting the O2 sensor out for access to one of the bolts on the engine side for removing the OEM pipes.
After the car got totaled, it took ~1 hour to remove the aftermarket pipes, in a parking lot, with a jack, jack stands, and electric impact.
I asked a shop once and they quoted me $200 for install, which was about 2.5 hours.
irondoor19
#19
Will take some picks of the Downpipe re-install...
after i get the DPs Wrapped and Sealed, Next Week Latest....
tried to post pics, but will not take (too Big in size?)
It will take a shop roughly 90 min for the install but make sure to get your OEM DP back just in case you need to return to stock in the very near future.
I have to agree with Derfdog that a fair assessment would be roughly 200.00. for the install and might want to consider ordering new gaskets depending on the current mileage.  Z
X4 Gaskets needed.http://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,exhaust+&+emission,pipe+flange+gasket+/+seal,5836
http://www.rockauto.com/en/moreinfo.php?pk=7673764&cc=1503823&jsn=440&jsn=440
StealBlueSho
I had a local shop charge me $225 IIRC for the DP installation.. that included new gaskets, and having to re-weld new flanges onto the exhaust system since the original owner had a custom exhaust up to the cats...
lamrith
Quote from: ZSHO on March 31, 2017, 11:35:00 AM
Thanks Z!
You say 4x gaskets, but link brings up 3 differnet gaskets.
I believe the FEL-PRO 61236  and the MAHLE ORIGINAL/VICTOR REINZ F32679 are just two versions of the same gasket?
We basically need 2 of each type and have an option for one of them if I read it correctly?
Quote from: lamrith on March 31, 2017, 12:39:32 PM
Thanks Z!
Two for the Front. 9.66. ea
CONVERTER GASKET, LEFT - 2013 FORD TAURUS (AA5Z6L612A)
http://www.tascaparts.com/ford/taurus/aa5z6l612a/2013-year/sho-trim/3-5l-v6-gas-engine/exhaust-system-cat/exhaust-components-scat/?part_name=converter-gasket&position=left
http://www.rockauto.com/en/moreinfo.php?pk=7673764&cc=1503823&jsn=9
TWO FOR THE REAR 9.81 ea
FLEX TUBE GASKET, RIGHT - 2013 FORD TAURUS (7T4Z9450AA)
http://www.tascaparts.com/ford/taurus/7t4z9450aa/2013-year/sho-trim/3-5l-v6-gas-engine/exhaust-system-cat/exhaust-components-scat/?part_name=flex-tube-gasket&position=right
http://www.rockauto.com/en/moreinfo.php?pk=7673752&cc=1503823&jsn=10
Here's an additional 5% off at www.rockauto.com using the promo code below,enjoy.  Z  :)
[5836875752458461]
This Discount code expires on April 30,2017.
irondoor19
Quote from: irondoor19 on March 31, 2017, 11:25:25 AM
Used the Cheap Fiberglass kit from Ebay
Sealed with the High Temp Silicone.. Will Do Install Pics Tomorrow
Linemonkey
What am I doing wrong?! I can't get the front, primary O2 sensor back in. I can't get it to fit before or after I put the pipe on. Help!
Sent from my SAMSUNG-SM-G930A using Tapatalk
2013 SHO PP Tuxedo Black
3 bar
160 T-STAT
Catless DPs
Tune by AJP
Quote from: Linemonkey on May 05, 2017, 04:15:19 PM
I hope you don't have the SW DP!! ...some of the previous versions needed to be modified because of the 02 sensor Bung being at the wrong location  and not being able in to reach.  Z
Linemonkey
Apparently, SW put the O2 bung at a slightly different angle than it should be... great
3 bar
160 T-STAT
Catless DPs
Tune by AJP
Linemonkey
Quote from: ZSHO on May 05, 2017, 04:29:40 PM
I hope you don't have the SW DP!! .Z
Yeah. I'm totally screwed, now. I wish I'd known about this beforehand! Now I've damaged the sensor and have to replace it. As far as I can tell I have two options. 1. Order an O2 90* elbow and don't drive my car for several days, while it gets here. 2. Splice extra wire into the new sensor and put it in the rear bung. (catless) What do you think?
3 bar
160 T-STAT
Catless DPs
Tune by AJP
Quote from: Linemonkey on May 05, 2017, 04:39:21 PM
I feel your pain brother!! I used a 90 deg elbow the first time around.  Z
