Engine Woes on '10 Lincoln MKT 3.5
Started by zstring, July 07, 2016, 04:55:16 PM
zstring
🎶🎶"Music is the space between the notes" 🎶🎶
zstring
hold up... now i'm feeling REAL noobish... am i looking in the right place?
Fuel rail IS under the IM right?
zstring
nvm... i feel dumb... forgot a coolant line
Are you doing fuel injectors, then?
zstring
Quote from: SHOdded on July 12, 2016, 05:19:41 PM
Wow... if i told you what i had to go through the past few months... my MKT has been off the road since we last spoke.
I had to buy a GDI puller kit... check the injectors... buy 2 new injectors... get the money and then find the injectors. It was a PITA!!!! Not to mention ALL of the other life issues i was dealing with at the time!
but i finally got them.
Now i am in the process of putting them back in... btw... i bought an O-Ring Kit... only to find out that it only had parts for 4 injectors... but luckily, the injectors i bought had rings and seals installed. Gonna have to reuse 2 old clips... oh well!
zstring
i know that i saw replacement instructions on here somewhere... does anyone have a link to it?
zstring
zstring
Quote from: SHOdded on September 14, 2016, 02:18:44 PM
You mean this?
So... question... HOW important is it to torque to specs? Do i need to buy a torque wrench? lol
On a fuel system, I'd say it's a requirement, not an IF.  Torque wrenches from Harbor Freight work well enough to get by, and not expensive at all.
zstring
so... overall update.... over a year later! Replaced the injectors... helped A BUNCH... (at least i can drive it now!) Still have p0020 (ended up replacing it, but code came BACK up) and p0150. Now, I'm working on that
Better late than never!  P0150?  First time I have seen that code mentioned.  Will have to research.
