I replaced PCV valve and the vent tube connecting valve to the intake manifold with brand new Ford OEM parts. The real kicker is I
still hear a hiss when listening with a vacuum hose "stethoscope". It's definitely much less of a leak than before, but it still sounds like a leak to me. My UPR catch can setup is on the way which would eliminate this stupid hose, but I'm not sure why the new OEM hose still appears to leak at vacuum. I suspect it also leaks under boost as well, but it'd take Evil Knievel to test that theory. I'd like to get this issue 100% sorted before changing anything (tune, catch can, meth, etc...)
I took a video of the fuel trims and me rambling on a bit, you can see that
here. I apologize for the vertical video, the way I've got the Torque phone propped up fries my brain and I feel like I have to hold my iPhone that way too.
The LTFT1 seems stuck at 10.9% throughout my last few videos. Unsure why. They were both 10.9%, but LTFT2 is now 0.0%. The I let the car idle a bit, but didn't drive it, I still have air in my cooling system that I need to sort out, and I was home on my lunch break. Unsure if it's "safe" to drive. Is there a proper way to reset this besides clearing the codes at idle?
Any chance this could be bad gas as well? Maybe I got a bad tank and it put a unhappy injector into full failure and is causing this mess? I'm hesitant to assume that since my LTFT is only odd on a single bank. Any insight as to what to try next would be greatly appreciated.
