Quote from: sholxgt on June 17, 2016, 11:26:58 AM
Awesome! Really looking forward to the end result. I may follow in your footsteps with a 10" sub just because I'm lazy. LOL
Do you think the 12 could have been top mounted or would it have required substantial metal trimming?
Side note...I found out the hard way with my last car to not use a cutting wheel on the rear deck. I got the whole job done and everything looked great until I found out that the sparks that the grinding wheel threw off actually made permanent melted marks in the back glass. Doh!!!
Wow, would have never guessed that about the sparks. No, you can't fit the 12 from up top. Maybe a 10, the opening is 9.75". I wanted the bottom mount so i can access it easily, I only want to take all that crap out once if possible! For free air the bigger the better so that is why I went with the 12, that ring was easy to build, I have a cheap band saw that made short work of it.
