Ford F150
Started by zamirlihari, May 29, 2016, 05:33:48 PM
FORD RECALLS 2017 F-150 OVER TRANSMISSION PROBLEMS
October 26, 2017The same day Ford recalled 15,000 model year 2018 F-150 trucks for problems related to gear shift levers, the automaker also announced a recall of 15,000 model year 2017 F-150s for their own shift lever problems.
The 2017 trucks are equipped with 10-speed automatic transmissions that can remain in gear no matter where the gear shift lever is positioned. Ford says a pin that attaches the transmission shift linkage to the transmission can come out, leaving the shift lever unable to change gears.
The shift lever indicator may display the wrong information and the key can be removed even if the truck is not in PARK. This will cause a warning chime and a message in the instrument cluster, but the truck won't start if the transmission is not in NEUTRAL or PARK.
Then there is the very real problem of the truck rolling away if a driver doesn't apply the parking brake. However, Ford doesn't know of any reported crashes or injuries related to the transmission problems.
The automaker says some of the F-150 trucks were built in Kansas City between September 2016 and August 2017, while the remaining trucks were built in Michigan between August 2016 and July 2017.
About 11,783 of the recalled trucks are in the U.S., 3,169 are in Canada and 701 are in Mexico.
Ford dealers will remove the roll pins and replace them with updated parts, but for now F-150 owners should make sure the parking brakes are applied at all times when the trucks are parked.
There has been no recall date announced, but concerned truck owners may call Ford at 866-436-7332 and refer to recall number 17S36.  Z
https://www.carcomplaints.com/news/2017/ford-recalls-2017-f-150-transmission-problems.shtml
SSM 46896 – 2018 F-150 – 2.7L Gasoline Turbocharged Direct Injection (GTDI)/3.5L GTDI – Transport Mode
It is important to keep 2018 F-150 vehicles equipped with a 2.7L GTDI or 3.5L GTDI engine in Transport Mode until the vehicle is being prepared for customer delivery.
Transport mode reduces battery drain during extended periods when the vehicle is not in use and contains an alternate calibration that reduces the chance of spark plug fouling during engine idle and or frequent engine start and stop events when engine does not read normal operating temperature.
APPLICABLE VEHICLES
2018 TRUCK: FC P552 F150
2018 – F-150 – Ambient Lighting – Multi-Color Settings Inoperative
2018 F-150 vehicles equipped with ambient lighting will only have a single color.
The multi-color option, ability to dim and turn on/off are no longer available in 2018 model year.
No repair attempts should be made to address the ability to enable color change, dim or turn on/off the ambient lighting feature.
SSM 47099 – 2018 Mustang 5.0L and F-150 2.7L, 3.3L, 3.5L and 5.0L- Malfunction Indicator Lamp (MIL) With Diagnostic Trouble Code (DTC) P0181 – Engineering Investigation
Some 2018 Mustang equipped with 5.0L engines and F-150 equipped with 2.7L, 3.3L, 3.5L and 5.0L engines may exhibit illuminated Malfunction Indicator Light (MIL) with Diagnostic Trouble Code P0181 (Fuel Temperature Sensor A Circuit Range/Performance) stored in Powertrain Control Module (PCM) memory.
DTC may set if Key On Engine Running (KOER) diagnostic routine is performed with cold fuel (Below 50F/10C) in vehicle fuel tank.
Refer to the Powertrain Control/Emissions Diagnosis (PC/ED) Pin Point Test DD for normal diagnostics.
If unable to determine root cause, do not replace fuel pressure/temperature sensor or Powertrain Control Module (PCM).
Engineering is investigating, monitor OASIS for updates.
Ford recalls 350,000 trucks, SUVs for transmission issue.
The vehicles could roll when put into park.
The recall includes the latest versions of the F-150 and Expedition.
Ford is issuing two separate safety recalls to fix mechanical issues affecting control of the transmissions on certain 2017 and 2018 models. The automaker says it's aware of one reported accident with an injury related to the the first and largest recall.
That safety recall affects nearly 350,000 pickups and SUVs from the 2018 model year to fix a potentially unseated gear shift cable locking clip that could leave the transmission in a gear state different from what the driver selects — meaning the vehicle could move even when placed in park, if the parking brake isn't activated, with no warning message on the instrument panel or warning chime when the driver-side door is opened. The recall affects 2018 F-150, F-650 and F-750 trucks and 2018 Expeditions equipped with six- and 10-speed automatic transmissions.
Dealers will inspect the vehicles to ensure that the shift cable locking clip was properly installed and will secure the locking clip at no charge to the customer if it was not.
The recall reference number is 18S10.
The affected vehicles are:
2018 Ford F-150 trucks built at Dearborn Assembly Plant between Jan. 5, 2017, and Feb. 16, 2018
2018 Ford F-150s built at Kansas City Assembly Plant between Jan. 25, 2017, and Feb. 16, 2018
2018 Ford Expedition SUVs built at the Kentucky Truck Plant from April 3, 2017, to Jan. 30, 2018
2018 Ford F-650 and F-750 medium-duty commercial trucks built at Ohio Assembly Plant between April 25, 2017, and March 9, 2018
The second recall targets 161 F-150s and Expeditions, Lincoln Navigators and Ford Mustangs equipped with 10R80 transmissions that may be missing a roll pin that attaches the park pawl rod guide clip to the transmission case. If missing, the 10-speed transmission over time could lose park function even when the instrument panel display and shifter show the vehicle is in park mode and without warning message or door chime. Ford says it knows of no injuries or accidents related to this problem.
Dealers will inspect recalled vehicles and make repairs free of charge. The reference number is 18S09.
2017-2018 Ford F-150 trucks built at Dearborn Assembly between Oct. 20, 2016, and March 5, 2018
2017-2018 F-150s built at Kansas City Assembly from Dec. 22, 2017, to Feb. 26, 2018
2018 Expeditions made at Kentucky Truck Plant from Nov. 28, 2017, to Feb. 14, 2018
2018 Mustangs built at Flat Rock Assembly Plant from Nov. 6, 2017, to Feb. 12, 2018
2018 Navigators built at Kentucky Truck from Dec. 13, 2017 to March 8, 2018
https://www.autoblog.com/2018/04/06/ford-recalls-350000-truck-suv-transmission/
https://www.cnet.com/roadshow/news/ford-recall-350000-trucks-suvs-transmission-problems/
FORD RECALLS F-150S, EXPEDITIONS AND LINCOLN NAVIGATORS
F :oord recalls 7,500 trucks and SUVs because of welding problems related to the fuel pumps.  Z   ???
JUNE 13, 2018 — Ford has fuel pump problems that affect about 7,500 model year 2018 Ford F-150 trucks and 2018 Ford Expedition and Lincoln Navigator SUVs equipped with 3.5-liter GTDI V6 engines.
The trucks and SUVs have misaligned welds between the high-pressure fuel pump housings and their mounting flanges that can allow fatigue cracks and fractures.
This in turn will cause the fuel pumps to move out of their intended positions. Ford says the seals of the cam covers or fuel lines will be affected and possibly allow oil or fuel to leak.
Although oil or fuel could possibly leak and make contact with an ignition source, Ford is unaware of any fires, crashes or injuries related to the fuel pumps.
The recall includes 5,645 trucks and SUVs in the U.S., another 1,625 in Canada and 310 vehicles in Mexico.
Ford didn't say when the recall will begin, but dealers will replace the fuel pumps, the high-pressure fuel discharge tubes and the mounting bolts.
Affected customers with questions should call 866-436-7332 and refer to recall number 18S17.
http://m.carcomplaints.com/news/2018/ford-recalls-f-150-expeditions-lincoln-navigator.shtml
DETAILS:  https://www.ecoboostperformanceforum.com/index.php/topic,8122.msg140438.html#msg140438
SSM 47377 – 2017-2018 F-150 – 3.5L EcoBoost – Oil Pan Leak – Built On Or Before 26-Feb-2018
Some 2017-2018 F-150 vehicles equipped with a 3.5L EcoBoost engine built at Kansas City Assembly Plant on or before 23-Feb-2018 or Dearborn Truck Plant on or before 26-Feb-2018 may exhibit an oil leak from the oil pan RTV seal.
Replace the oil pan following the procedure in Workshop Manual (WSM) Section, 303-01.
After removing the oil pan, it is suggested to allow the crankcase to drain over night to minimize the chance of contaminating the sealing rail.
Prepare the engine sealing surface following the procedure in WSM Section, 303-00.
Proper usage of the Motorcraft® Metal Surface Prep Wipes is critical.
If possible, allow the new RTV sealant to cure for 4 hours before refilling the engine with oil.
Correctly following the WSM procedures is critical.
Skipping or improperly completing steps may result in repeat oil pan leaks.
APPLICABLE VEHICLES
2017 – 2018 TRUCK: FC P552N F-150
SSM 47394 – 2013-2018 F-150, 2015-2018 Transit/Expedition, 2015-2017 Navigator – 3.5L EcoBoost – Engine Tick Type Noise From Cylinder Block
Some 2013-2018 F-150, 2015-2018 Transit/Expedition, and 2015-2017 Navigator vehicles equipped with a 3.5L EcoBoost engine with greater than 20,000 miles may exhibit a tick type noise from the cylinder block area.
This noise may be caused by a cracked piston skirt.
The noise can be isolated to a cylinder using a stethoscope or other suitable listening device.
Canceling the affected cylinder will reduce or eliminate the noise.
If the noise is isolated to a specific cylinder, it is recommended to replace the short block.
If the noise cannot be isolated using the methods described, refer to the Workshop Manual (WSM) for diagnosis.
A cracked piston skirt does not result in metal contamination of the engine or any related cylinder head damage.
Prior approval for short block replacement is not required under new vehicle limited warranty coverage.
APPLICABLE VEHICLES
2015 – 2018 TRUCK: TH V363N TRANSIT
2013 – 2014 TRUCK: F6 F150/LINCOLN MARK LT
2015 – 2018 TRUCK: FC P552N F-150
2018 TRUCK: B8 U553N EXPEDITION
2015 – 2017 TRUCK: B7 U222N EXPEDITION
2015 – 2017 TRUCK: B5 U228N NAVIGATOR
SSM 47342 – 2018 F-150 Excluding Raptor – Ambient Air Temperature (AAT) Sensor Located in Exterior Mirror – Built On Or After 10-Mar-2018
2018 F-150 vehicles excluding Raptor built at Dearborn Truck Plant on or after 26-Feb-2018 and at Kansas City Assembly Plant on or after 10-Mar-2018 have the AAT sensor located in the right exterior mirror.
The AAT sensor was relocated from the front grill/fascia area.
The AAT sensor is serviced separately from the mirror.
Refer to Ambient Air Temperature Sensor GSB G0000178 for additional information.
The Workshop Manual (WSM) is in the process of being updated for non-Raptor vehicles.
The sensor location on Raptor vehicles has not changed
APPLICABLE VEHICLES
SSM 47343 – 2015-2018 F-150, 2017-2018 F-Super Duty – Lack Of Cooling From HVAC System – Low Refrigerant Charge
Some 2015-2018 F-150 and 2017-2018 F-Super Duty vehicles may exhibit a lack of cooling from the heating ventilation air conditioning (HVAC) system due to a low refrigerant charge.
Using an ultraviolet (UV) leak detection light, inspect the condenser near the receiver/dryer cap for the presence of dye.
If dye is present, replace the condenser.
For claiming, use causal part 19712 and applicable labor operations in Section 11 of the Service Labor Time Standards (SLTS) Manual
APPLICABLE VEHICLES
2017 – 2018 TRUCK: FE P558N SUPER DUTY
SSM 47337 – 2018 F-150 – 3.3L – Illuminated Malfunction Indicator Lamp (MIL) And/Or Runs Rough – DTC P0192 And/Or P0193 – Built On Or Before 31-May-2018
Some 2018 F-150 vehicles equipped with a 3.3L engine built on or before 7-May-2018 at Dearborn Assembly Plant or on or before 31-May-2018 at Kansas City Assembly Plant may exhibit an illuminated MIL and/or runs rough condition with DTC P0192 and/or P0193.
Various other DTCs may be set.
This may be due to engine harness chaffing at the right cylinder head near connector C1056 at the cylinder head core plug boss.
The connector will need to be removed from the retainer to inspect the back side of the harness for any damage.
Repair as necessary.
Make sure to wrap the exposed wiring with Rotunda Coroplast Electrical Wire Harness Tape (RTTP part number NAI837X or equivalent) and reposition the harness to prevent future chaffing concerns.
For claiming, use causal part 12A581 and applicable labor operations in Section 10 of the Service Labor Time Standards (SLTS) Manual.
APPLICABLE VEHICLES
SSM 47360 – 2013-2018 F-150, 2017-2018 Expedition/Navigator – Intermittent Grinding Noise From Integrated Wheel Ends (IWE) While Driving In Two Wheel Drive (2WD)
Some 2013-2018 F-150 and 2017-2018 Expedition/Navigator vehicles may exhibit an intermittent grinding noise coming from the right or left IWE area in 2WD mode.
This may be caused by an intermittent leak in the check valve.
Before completing any normal diagnosis suspect that the check valve is the root cause of the issue.
If the check valve has been ruled out as the root cause for the issue refer to Work Shop Manual 308-07 and follow normal diagnosis.
APPLICABLE VEHICLES
2013 – 2017 TRUCK: B7 U222N EXPEDITION
2013 – 2017 TRUCK: B5 U228N NAVIGATOR
2018 TRUCK: B9 U554N NAVIGATOR
SSM 47322 – 2018 F-150 – 5.0L – Illuminated Malfunction Indicator Lamp (MIL) – DTCs P0087 And/Or P00C6 After High Pressure Fuel Pump Replacement
Some 2018 F-150 vehicles equipped with a 5.0L Port Fuel Direct Injected (PFDI) engine may exhibit an illuminated check engine lamp with DTC P0087 and/or DTC P00C6 stored in the PCM following a repair in which the fuel system was opened.
This concern may be due to not pressurizing the fuel system before starting the engine.
After reconnecting the fuel pump driver module (FPDM), cycle the ignition on and wait 3 seconds to pressurize the fuel system.
The Workshop Manual (WSM), Section 303-04 is being updated to emphasize this direction.
APPLICABLE VEHICLES
SSM 47384 – 2018 F-150 – Genuine Ford Accessory (GFA) Or Aftermarket Trailer Brake Controller (TBC) Installation
Some 2018 F-150 customers may request a GFA TBC or aftermarket TBC kit be installed.
Depending on vehicle content, the battery junction box (BJB) may not have the necessary fuse and/or terminals to provide power to the TBC.
If the BJB has terminals present at the F24 location, the 30A M-Case fuse GU5Z-14526-H found in the GFA TBC kit JL3Z-19H332-AA can be inserted into the BJB F24 location and the GFA TBC install can be completed.
If fuse F24 and terminals are not present, a fused jumper harness kit JL3Z-14A411-C must be installed.
The jumper harness and TBC installation instructions are available at www.accesssories.ford.com.
Vehicle option content determines the need to install the additional fused jumper harness kit, therefore the purchase and installation of the kit is non-warrantable.
Part Name    Part Description
30A Fuse    GU5Z-14526-H
GFA TBC Kit    JL3Z-19H332-AA
APPLICABLE VEHICLES
SSM 47312 – 2018 F-150 – Floor Shift Transmission Selector Lever – Floor Shift Gear Selection Indicator (PRNDL) Not Illuminated – Built On Or After 17-Jan-2018
2018 F-150 vehicles equipped with a floor shift transmission selector lever built on or after 17-Jan-2018 are not equipped with an illuminated gear selection indicator (PRNDL) on the transmission selector lever assembly.
Do not attempt any repairs or replace any parts for this condition.
APPLICABLE VEHICLES
