Started by JDW1, May 21, 2016, 06:22:36 PM
Quote from: sholxgt on July 15, 2016, 03:28:30 PMJust got PPE down pipes in the mail For those of you that changed yours...did you reuse the factory gaskets or did you get new ones? I just called the dealership and ordered two of what shows as part 6L612 on Fordparts.com. They are listed as "Catalytic Converter Gasket." Are those what I need? Are there others I should order?
Quote from: ZSHO on July 15, 2016, 04:24:44 PMDefinitely change them considering the exhaust levels only reach up to 500 degrees,lol #3 AND # 8 ON the diagram is what you need a total of four are needed,hope this help's any. Z http://www.tascaparts.com/auto-parts/2013/lincoln/mks/ecoboost-trim/3-5l-v6-gas-engine/exhaust-system-cat/exhaust-components-scat
Quote from: EcoPowerParts on July 15, 2016, 04:35:35 PMQuote from: sholxgt on July 15, 2016, 03:28:30 PMJust got PPE down pipes in the mail For those of you that changed yours...did you reuse the factory gaskets or did you get new ones? I just called the dealership and ordered two of what shows as part 6L612 on Fordparts.com. They are listed as "Catalytic Converter Gasket." Are those what I need? Are there others I should order?I reused mine several times of in/out never had a problem
Quote from: sholxgt on July 15, 2016, 04:53:49 PMQuote from: EcoPowerParts on July 15, 2016, 04:35:35 PMQuote from: sholxgt on July 15, 2016, 03:28:30 PMJust got PPE down pipes in the mail For those of you that changed yours...did you reuse the factory gaskets or did you get new ones? I just called the dealership and ordered two of what shows as part 6L612 on Fordparts.com. They are listed as "Catalytic Converter Gasket." Are those what I need? Are there others I should order?I reused mine several times of in/out never had a problem Thanks! Good to know that as well. I already have the turbo to cat gaskets on order. Those I don't want to have to change again. I will probably try re-using the rear gaskets since those are much easier to change later. Who knows...those may get changed with a cat-back install someday
