May 27, 2020, 09:40:16 am
Author Topic: Articles on Engine Design  (Read 26888 times)
Offline Gjkrisa
  • Fairbanks, AK
  • -Given: 974
  • -Received: 217
    • Photos
Re: Articles on Engine Design
« Reply #30 on: March 22, 2019, 10:18:11 am »
I find it amusing Ford says no break in period yet certain cars have special oil in the crankcase when new.
True I thought they broke them in on a machine but then why not change the oil before it's put in a car
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #31 on: March 22, 2019, 10:30:39 am »
Probably not a big difference for cars driven modestly from the get go.  Does not hurt to be aware though.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #32 on: March 23, 2019, 08:38:05 am »
Vehicle Miles Traveled vs VOC Emissions TLT
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #33 on: April 18, 2019, 07:52:51 am »
Oil seal leaks in turbocharged engines operating in extreme winter conditions.  The culprit?  Ice formation in the PCV system.  Another reason to allow engines to warm up before excercising that go pedal.
https://www.enginebuildermag.com/2013/08/mysterious-leaking-engine-oil-seals-on-subaru-engines/
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #34 on: April 21, 2019, 08:18:05 am »
Intake Valve Deposits (IVD) ... Where do they come from?
PCV System - Intact Oil - 71% of the deposit weight; unevenly distributed to each cylinder
Exhaust/EGR System - Combusted oil
https://www.thefreelibrary.com/Formation+of+intake+valve+deposits+in+gasoline+direct+injection...-a0478973886
LUBRICANT COMPOSITIONS FOR DIRECT INJECTION ENGINES
http://www.freepatentsonline.com/y2018/0346843.html
« Last Edit: April 21, 2019, 08:37:27 am by SHOdded »
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #35 on: April 22, 2019, 06:11:00 pm »
Look to the GM Turbocharger Coking test for determining effects of engine oil & its' components to determine effectiveness of deposit control in coolant-cooled turborcharger systems.  The TEOST 33C test, developed to determine engine deposit control, is ineffective in this area.  Moly does not affect deposit levels, but viscosity modifiers and antioxidants do.
https://www.thefreelibrary.com/Engine+Oil+Components+Effects+on+Turbocharger+Protection+and+the...-a0532023053
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #36 on: April 24, 2019, 06:23:58 pm »
Installing the Turbos on the assembly line - Cleveland Plant Tour at the 2010 SHO convention
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #37 on: April 24, 2019, 06:24:31 pm »
Installing the Rear Main Seal - Cleveland Plant Tour at the 2010 SHO convention
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #38 on: November 05, 2019, 07:05:12 pm »
Temperature considerations in the combustion chamber - piston area
https://www.dieselnet.com/tech/combustion_piston-cool.php
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #39 on: November 05, 2019, 08:48:03 pm »
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #40 on: November 05, 2019, 08:51:17 pm »
Taking apart your engine?  Evaluating pistons?  There's more than meets the eye to recertifying a piston for use:
http://blog.jepistons.com/evaluating-used-pistons-how-to-determine-if-your-pistons-are-still-good
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #41 on: November 22, 2019, 04:11:08 am »
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #42 on: November 22, 2019, 04:53:11 am »
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1932
  • -Received: 4056
« Reply #43 on: November 22, 2019, 07:05:47 pm »
Great informative reading! Z  :)
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #44 on: November 22, 2019, 07:53:14 pm »
Some stuff you would have to dig to find otherwise :)  I found it very interesting as well!
* Featured Topics
* Recent Topics
2016 Black SHO from Mi
by Michigan-SHO | Today at 09:37:55 am
After months of searching I was able to get a stock 2016 black SHO non...
Re: 802SHO 2010 Build
by 802SHO | Today at 06:17:39 am
Honestly that's not alot of $ for better flow vs our manifolds IM...
by bpd1151 | Today at 01:21:26 am
I'm hoping that that opening line is laden with sarcasm.Actually ...
Re: Updated Gallery Capabilities
by bpd1151 | Today at 01:10:42 am
I have some time off from work coming up soon. I'll have to check...
Re: Transfer case torque limit
by 10sleeper | Today at 12:43:07 am
My tuner just noticed that I was hitting my transfer case torque limit...
Re: For those looking for something different for a 2nd (or 3rd) car
by FoMoCoSHO | May 26, 2020, 11:23:21 pm
There is another CON if you are a DIY type...The packaging is slick bu...
Re: Thinking of trading the 16S H O
by Gjkrisa | May 26, 2020, 09:28:19 pm
I almost bought a dodge/jeep/Chrysler product once....nah I didn'...
Re: Does anyone here have a Taurus 2.0 EB?
by GhostlyGrenade | May 26, 2020, 07:35:35 pm
They must be giving SCT devices away. There's no way people are s...
Re: MRT blues
by StinkinLinkin13 | May 26, 2020, 04:32:36 pm
We'll my four muffler setup is a winner for me. Its not pretty ri...
Ecoboosted Gallery!!
by StealBlueSho | May 26, 2020, 11:27:31 am
Add a picture of your ecoboost or your favorite ecoboosted picture! It...
Re: MrHighCALiber's SHO Forged Engine Build
by 802SHO | May 26, 2020, 05:15:44 am
That's crazy!  Looks like she won't be down for long in...
Re: EBPF Under New Ownership!
by 76fomoco | May 25, 2020, 12:19:53 pm
SBS thanks for picking up the torch and keeping this wealth of informa...
Re: EPP CAI
by 802SHO | May 25, 2020, 05:58:21 am
I ordered mine last week and it's sitting on the bench. I figured...
Re: Letís talk weight reduction?!
by 802SHO | May 25, 2020, 05:42:56 am
I think it's worth it for a couple reasons...first being youre fa...
Re: Ford Recalls
by BlueSHO | May 24, 2020, 11:16:02 pm
FORD EXPLORER RECALL: SUSPENSION PROBLEMS IN 1.2 MILLION SUVS. Z ...
Back to top
