Ecoboost Performance
Troubleshooting, Maintenance, TSB Articles
Troubleshooting
"AWD OFF" Light
"AWD OFF" Light
Started by Gray Brick, April 20, 2016, 02:25:23 PM
3
Gray Brick
Sr. Member
Gray Brick
Re: "AWD OFF" Light
#30
June 03, 2016, 01:48:20 PM
Problem solved..... shaved the rear tires 5/32"
The fronts and rears are within 1% now.
If needed I can run a little less tire pressure in the rear to make up for this.
2013 Ecoboost Ford Flex
Forum Supporters
Re: "AWD OFF" Light
#31
June 03, 2016, 01:51:33 PM
Gray Brick
Sr. Member
Gray Brick
Re: "AWD OFF" Light
#32
June 04, 2016, 02:46:56 AM
295-40/20 rear 91.5" circumference
275-40/20 front 90" circumference
1.66% difference between front and back.
This is about half of the recommended difference recommended by Ford of 3%
No worries about putting stress on the drive train now.
CroR1
2014 SHO PP
That's right
Re: "AWD OFF" Light
#33
June 04, 2016, 12:23:40 PM
How did you shave the tires?
Gray Brick
Sr. Member
Gray Brick
Re: "AWD OFF" Light
#34
June 04, 2016, 02:11:18 PM
A few racing companies offer it as a service.
I Googled "tire shaving"
None of the large tire companies offer it.
$20/tire
I had them take off 5/32"
CroR1
2014 SHO PP
That's right
Re: "AWD OFF" Light
#35
June 04, 2016, 05:10:40 PM
Interesting, I didn't know that.
3
Troubleshooting
"AWD OFF" Light
