Started by Scott4957, April 18, 2016, 09:49:19 PM
Quote from: Scott4957 on April 18, 2016, 09:49:19 PMIts on its way! I'm considering using the washer fluid tank for a hidden install, anyone have a link to the parts need to tap both the washer tank and the plastic intake pipe? Anything else that is recommended?Thanks,Scott
Quote from: Scott4957 on April 19, 2016, 07:50:52 AMThank you, I couldn't find it because the name bulkhead was escaping me at the moment. I thought the made a similar or maybe it's the same part for the nozzle when using plastic pipeing. Sounds like most tap the plastic without issue. I would also like to buy another plastic elbow in case I have to return to stock for maintenance. Sent from my SM-N910V using Tapatalk
