MKT AWD PTU Serviced
Started by akakooper, February 05, 2016, 12:19:04 PM
BlueSHO
Quote from: ZSHO on February 05, 2016, 09:31:43 PM
Quote from: pmezo33 on February 05, 2016, 09:20:07 PM
Quote from: JeffsSport on February 05, 2016, 08:42:45 PM
Quote from: pmezo33 on February 05, 2016, 08:14:20 PM
It's really no big deal to change your ptu or rdu fluid.  Very simple job that any DIYer can do.  It actually takes longer to put the car on jack stands than the actual draining and filling of the fluids.  I've done the ptu twice on my mks so far and the last time it took me 15 minutes once the car was up in the air.  The rdu takes about 10 minutes to do and most of that is pumping the new oil in the differential.
Is there a how to somewhere I could look at?
PTU.  I think i remember reading that the procedure is slightly different with PP sho's and that you may have to drop the down pipe, but not 100% sure on that.  You'll need someone else to confirm that though.
http://www.ecoboostperformanceforum.com/index.php/topic,3360.0/topicseen.html
RDU
http://www.ecoboostperformanceforum.com/index.php/topic,1708.msg21702.html#msg21702
Pmezo is correct,you will actually have to remove the passenger side DP in order to gain full access to the plug/sensor on the PP SHO.  Z
What's the difference on the PP or non PP SHO that makes the ptu oil change different?
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
pmezo33
#16
Quote from: JeffsSport on February 05, 2016, 10:12:06 PM
That you need to drop the downpipe to gain access to the plug.  You don't need to do that with the non pp cars.
BlueSHO
Quote from: pmezo33 on February 05, 2016, 10:20:42 PM
That you need to drop the downpipe.  You don't need to do that with the non pp cars.
I understand that but why is that
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
pmezo33
Quote from: JeffsSport on February 05, 2016, 10:23:59 PM
Probably just the way the car was designed.  I've never done it on a PP car, but I'm guessing you can't get to the ptu fill plug without removing the downpipe.
BlueSHO
Quote from: pmezo33 on February 05, 2016, 10:28:56 PM
Ok got ya..
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
RDU
Its a night and day difference,the PITA PP because of the oil cooler and heatshield  making access to the plug imposible without having to remove the passenger DP as mentioned earlier,also you will need a special tool in order to gain full access to the plug,had mine changed at roughly 32k,PICS below and hope this helps any.  Z
So it sounds like I should change the PTU fluid when I have the DPs installed?
Quote from: FoMoCoSHO on February 05, 2016, 10:49:09 PM
Correct kind sir,kill two birds with one stone and some fresh Amsoil 75w-140 fluid for a nice touch.  Z     :)
Quote from: ZSHO on February 05, 2016, 10:55:32 PM
Correct kind sir,kill two birds with one stone and some fresh Amsoil fluid for a nice touch.  Z    :)
No Amsoil this go around, have the BND Quantum Blue ready to go.
Quote from: FoMoCoSHO on February 05, 2016, 11:06:36 PM
Sean cant wait to hear your analysis on the Q.Blue.  Z      :thumb:
Ooooo, FoMoCo bleeds again (in the name of science).  Will it truly be blue?  Stay tuned ...
Quote from: SHOdded on February 05, 2016, 11:18:41 PM
-MANU now thats funny,its not easy to make me laugh.lol.  Z
Quote from: ZSHO on February 05, 2016, 11:16:57 PM
I already have the oil in the crankcase. I need to drop off my OEM "breakin" oil for analysis.
Haha, my wallet did all the bleeding, LOL...
I'm having a hard time not buying that straight <<0 viscosity synthetic....
I have a problem and there is a dealer close, lol...
Quote from: FoMoCoSHO on February 05, 2016, 11:29:33 PM
No direct injection allowed.
