Cincinnati Area Maintenance
Started by jeffrey13, February 04, 2016, 11:29:55 AM
peppelepugh
Quote from: jeffrey13 on March 09, 2016, 12:05:40 AM
Thanks everyone for the help!! I found a dealer who changed the wheel bearing and fixed the PTU leak all under the extended warranty!!!
What dealer did you end up going to?
2011 Kona Blue SHO non-PP: MDesign Carbon Fiber CAI, All interior lights LEDs, LED Puddles, and LED Reverse.
EBC Stage 4 Brake kit, 170* T-stat, 3-Bar MAP, NGK Plugs, PPE Catless-DPs and Tune by Torrie!
jeffrey13
Walt Sweeney Ford. That's where I bought the vehicle.
2010 Ingot Silver Lincoln MKS
LMS 4x Tune, 3 Bar Map Sensor,SP534 Plugs
170 Tstat
K&N drop in Filter
jeffrey13
Ok so after 3 PTU seals they are replacing the PTU today! I was curious if there is anything I should look for after the replacement other than leaks of course. Thanks!!
170 Tstat
K&N drop in Filter
New PTU - good!  Check that the fluid is properly topped off before driving it away?
jeffrey13
Will do thanks!
170 Tstat
K&N drop in Filter
pmezo33
#20
Quote from: jeffrey13 on June 30, 2016, 12:22:54 PM
Make sure it's not your turbo that's leaking oil since the seals aren't fixing anything.  It might not even be your ptu at all.  That spot is right below the rear turbo.  As you drive, the oil can be blowing onto your ptu shaft.
