Quote from: ajpturbo on January 27, 2016, 01:10:26 AM
I log around 30 PID's when I log. I don't see how you can do that without SCT. And to be thorough when trying to diagnose something I would log as much as possible.
I would be interested in STFT's, measured AFR, Actual throttle angle, Fuel pressure at the rail, Misfire count, Knock senor, TIP and MAP pressure, in addition to normal things like RPM, Coolant temp, gear, IAT's, vehicle speed and spark and cam timing intake actul..
Popping can't be good and means something. I doubt the higer E would be a problem but the more you have the more your stft's and ltft's would read.
AJPTURBO
Sorry for the late response on this post
This shows your inexperience with engines an fuel. E85 will most definitely cause popping with these cars (IF OUT OF FUEL). The car is on the verge of being out of fuel pressure and lean on e10 gasoline. Please don't advise people with inaccurate advice. This kind of stuff causes major problems with the fuel system and engine. I wish people would advise the correct information. The winter is here an temperatures are colder which results in substantially more fuel required (especially with E85).
You seem to know very little about datalogging, a pid is no where near the data you need to be looking at with "said" companies data log. It is for diagnostic data for repair shops. Not for development.
Can we confirm the actual fuel in the car?
We don't have people complaining with these cars about drivability issues since initial release in 2013. I think we are on to something with the fuel. We are committed to finding the problem out. If we need to we will make a trip to the customer an find out the problem. This is a car problem not a tuning problem.
We stand behind our customers
LME
Please educate the community with "good information" not opinion.
