Quote from: jimmyducati on January 23, 2016, 05:04:08 PM
ZSHO, the owners manual for the 2010 SHO specifically lists the back up camera as standard equipment... The website you listed just says it was an option on some models. I called the dealer I bought the car from and they suggested that I call back when service is open and ask to speak with the service manager. He didn't think it was a far fetched idea at all that the dealer might install the camera at no charge, "standard equipment is standard equipment" he said. Its obvious that this was a mistake on the assembly line, so with any luck I can get them to put it in for free! If not, ill just put it in myself and go to rock auto for parts.
If its standard equipment as you mentioned multiple times then there goes your answer because your not alone,many others have had the same issue. Z
