Started by Beaster1174, December 29, 2015, 04:11:10 PM
Quote from: slurppie on December 29, 2015, 07:07:03 PMI believe the PP sway bar is actually smaller in diameter than the non-PP due to other suspension upgrades. But, I've been wrong before. ...I think. Sent from my SM-G928P using Tapatalk
Quote from: panther427 on December 29, 2015, 10:27:04 PMwhat about strut tower braces.. It would be a fairly cheap part
Quote from: BiGMaC on December 30, 2015, 03:59:45 PMI believe the PI sway bars are stiffer than the other SHO's....
Quote from: bpd1151 on December 30, 2015, 04:37:18 PMQuote from: BiGMaC on December 30, 2015, 03:59:45 PMI believe the PI sway bars are stiffer than the other SHO's....They aren't. I used the VIN #'s off of/from my agency's PI Taurus' & learned that.As I stated previously, there's nothing out there.You have the Megan Coil Overs for the '10-'12 models, or the H&R Springs for all model years '10 & up....I found the adjustable end links, & worked directly with H&R to achieve the alignment solutions incorporating the adjustable rear camber bolts, but again, there's literally nothing else available out there as of now.Sent from my SM-N920V using Tapatalk
