Detailing, SYNC, AV, Security, Electrical, and Lighting
Exterior Modifications
Will they fit????
Will they fit????
Started by hghlndr85, May 31, 2016, 02:12:34 PM
hghlndr85
Jr. Member
Ecobooster
Will they fit????
Looming at getting these wheels for my 15 sho PP. Will they fit and clear the brakes?
CroR1
2014 SHO PP
That's right
Re: Will they fit????
May 31, 2016, 02:34:01 PM
Yes, they will fit, however, your tire option will be limited. The widest tire you may fit might be 245/255, depending on manufacturer, if you go with factory sidewall height. You would be better off getting something around 35-38 mm offset.
hghlndr85
Jr. Member
Ecobooster
May 31, 2016, 03:04:53 PM
I have 255 40 20 tires on stock pp wheels now.was going to just swap them.will these wheels stock out farther then stock or sit in more then stock
Forum Supporter!
RotM Winner
Ecobooster
May 31, 2016, 03:18:49 PM
Here's a link to a calculator that can help.
http://www.willtheyfit.com
Will they fit????
