What's going on all... I'm curious if the fluid selection creates the rust / failure issue. I do use some of the special bug / deicer fluid from time to time, which would make me wonder if it has to do with the fluid selection.
Besides that, I checked all of the fuses and they all look good. The wipers always work, and the pump doesn't even activate or hum, which to me tells me its dead or has a bad connection. I'll be digging more tonight and might pick up a pump at rock auto. The motorcraft pump is 19 ish on rockauto so its worth having a spare.
JMR, if you are going to be in the area, I'll never turn down a part, but I figure I need to get this part ordered and fixed before it snows in Wisconsin. Last, I think we still need to connect for Nav.
Also, my wipers always have activated on a flash, even when I had my wipers in the off position (versus auto).
