Rock Auto Closeout
Started by zamirlihari, December 10, 2015, 10:05:35 PM
POWER STOP K6375 Z23 Evolution Sport Kit ($50 Rebate Available!)   Sale! Front And Rear.  Z
Promo-code ^^^
GRAND TOTAL - $361.26
Get up to $50 back via mail in rebate with purchase of select Power Stop brake kits.
Offer expires 9/30/2018
https://www.rockauto.com/lang/en/promoCat.html#powerstop
https://www.rockauto.com/en/moreinfo.php?pk=5813034&cc=1503823&jsn=17
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,brake+&+wheel+hub,rotor+&+brake+pad+kit,13824
Motorcraft SP-542- Alternate part numbers CYFS092YPT, CYFS92YPT
$6.14 - ea- Grand Total  $38.99
https://www.rockauto.com/en/parts/motorcraft,SP542,spark+plug,7212
https://www.rockauto.com/en/moreinfo.php?pk=5931324&jsn=
This discount Promo- code expires on October 21, 2018
9054464683451274
www.RockAuto.com. Discount takes 5% off our reliably low prices. There is no limit on order size or the number of orders. Use the code for your next order, and share the code with anyone you know who works on cars or trucks.  Z   :)
This discount code expires on December 9, 2018
9379551188826095
TIMKEN HA590478 Front Wheel Bearing & Hub Assembly
for 13+ Performance Package SHO. Z
Promo-code ^^^
$127.79 - ea
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,brake+&+wheel+hub,wheel+bearing+&+hub+assembly,1636
https://www.rockauto.com/en/moreinfo.php?pk=4975638&cc=1503823&jsn=621
ABS/Non-ABS (Y/N)   N
ABS Type   Encoder
Bearing Type   BALL
Bolt Circle Diameter B (in)   4.494
Bolt Circle Diameter H (in)   #
Bolt Quantity   4.000
Bolt Size (in)   M12 x 1.5
Brake Pilot Dia (in)   2.678
Driven_Non Driven   Driven
Flange (#)   2.000
Flange Diameter (in)   5.739
Flange Offset (in)   1.690
Flange Shape   Trapezoid
Generation Type   X
Hub Pilot Dia G (in)   3.823
Lug Bolts_Bolt Holes (#)   Y
Roll Form (Y)   Y
Spline Quantity   38.000
Wheel Pilot Dia (mm)   63.250
Wheel Stud Qty   5.000
Wheel Stud Size (in)   43832.000
MOTORCRAFT VC10A2 Specialty Green Coolant (Concentrated) - Gallon . Z   :)
Grand Total of $29.78
https://www.rockauto.com/en/catalog/ford,2010,taurus,3.5l+v6+turbocharged,1445050,cooling+system,coolant+/+antifreeze,11393
BlueSHO
Quote from: ZSHO on October 23, 2018, 04:03:56 PM
Good deal but I think my 16 is orange
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
I believe the 2010MY & 2011MY which have a Build Date before 7/11 use the exclusive Green coolant IIRC!
The rest use the orange coolant to simplify things.  Z   :)
BlueSHO
Perfect thanks guys
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
Www.rockauto.com New Discount code below! Enjoy.  Z  :)
This discount code expires on December 30, 2018. 9551590790977375
MAHLE F32679 7T4Z9450AA Multi-Layered Steel
ID 2.25in; Left or Right Exhaust Flexible Pipe to Underbody Catalytic Converter. Z
$6.38 - ea
https://www.rockauto.com/en/moreinfo.php?pk=7673752&cc=1503823&jsn=10587
MAHLE F32686 AA5Z6L612A Multi-Layered Steel
Converter; ID 3.00in; Left or Right Turbocharger to Catalytic Converter.
$6.51 - ea
https://www.rockauto.com/en/moreinfo.php?pk=7673764&cc=1503823&jsn=10588
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,exhaust+&+emission,pipe+flange+gasket+/+seal,5836
I noticed the Price on the MOTORCRAFT DY1155-BH6Z9G444A Downstream Front 02 sensor have decreased a good amount of $$$. Z
$38.79
https://www.rockauto.com/en/moreinfo.php?pk=2604770&cc=1503823&jsn=12
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,exhaust+&+emission,oxygen+(o2)+sensor,5132
Www.rockauto.com Discount code below.  Z
96493055919127
The discount takes 5% off our reliably low prices. There is no limit on order size or the number of orders. Use the code for your next order, and share the code.
This discount code expires on January 13, 2019
DORMAN 939192  - DG1Z1015A Steelies. 18 In . Z
$107.79 - ea
GRAND TOTAL OF $463.56
Backspacing   169 MM
Bolt Pattern Diameter   114.3 mm
Bore Diameter   63.6 mm
Center Cap Included   No
Color   Black
Dimensions   18 x 8
Grade Type   Regular
Load Rating (lbs)   1675 Lbs.
Lug Hole Diameter   16.5 mm
Lug Hole Quantity   5
Offset (mm)   51 mm
Package Contents   1 Steel Wheel
Primary Bolt Pattern   5 x 114.3
Split Type   No
Tpms Compatible   Yes
Valve Stem Diameter   11.5 mm
Wheel Diameter (in)   495 mm
Wheel Finish   Painted
Wheel Material   Steel
Width (in)   236 mm
Alternate/OEM Part Number(s): DG1Z1015A
https://www.rockauto.com/en/moreinfo.php?pk=10354140&cc=1503823&jsn=10&jsn=10
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,wheel,wheel,7644
