2013 Taurus amp and sub
Started by adrian00111, December 05, 2015, 09:35:49 PM
adrian00111
I just picked up a 2013 Taurus sel. I ran all the wires for a amp and sub. Kicker L7 12" and a kicker 1500.1. I'm leaving the factory head unit since it's fully loaded. My question now is where do I install the line output converter (LOC)? I tried the rear speakers and it blew my head unit fuse twice. So any other place I can install this?
2013 Taurus SEL. 12" kicker L7. 1500.1 kicker amp. Sho grill.
adrian00111
Metra 2 channel.
I did the same thing with my 05 infinity g35 cope with no issues.
When you say rear speakers are you talking about the subs in the rear deck or rear door?
adrian00111
Ok, that's where most people who just add an amp connect to. Don't have any experience with the metro LOC. Never heard of popping a radio fuse with a LOC...
How are the gains set on the LOC.
A few members here have had good luck with this  http://www.amazon.com/AudioControl-2-Channel-Converter-Subwoofer-Control/dp/B004CTBYGE.
If you have the Sony premium sound the rear deck is subs only. And they're crossed over pretty high. If you want a full range signal and have your amp do the crossover work you need to tie into the rear doors.
All this can be done at the radio/amp interface in the trunk drivers side.
adrian00111
I'm a try the door speaker then. If nothing then I'll try the loc you adviced.
adrian00111
Update....
Used the rear left passage speaker and it works wonders now.
Quote from: adrian00111 on December 06, 2015, 07:34:06 PM
Update....
glad you got it figured out.
