Quote from: Xceler8x on November 17, 2015, 10:23:05 AM
Quote from: SHOnUup on November 13, 2015, 04:58:46 PM
Highly suggest upgraded pads...when i took the land yacht (2011 SHO) I cooked a set of EBC red stuff pads and slotted rotors being my first time out. These cars get up to speed fast for 4400 lbs and then need to be stopped!!!
The experienced guys were swearing by blank rotors with either Hawk or CarboTech pads.
It was a blast and the car did well...from driving with the more experienced guys in more track worthy cars, the SHO was holding corners at the same speeds...when i entered correctly
That is really encouraging to hear. I'm not expecting the family bruiser to be able to hang with even mildly prepped cars but it would be fun to take it out and dice it up some. I've got an E30 that I'm prepping for a combo date car/HPDE track rat. I would still like to get the SHO out there to see what it will do.
When you tracked yours did you have any modifications like brakes or suspension?
Good to know about rotor blanks and CarboTechs. I've never been a fan of crossdrilled or slotted rotors since I saw a Fox Mustang crack two front rotors in back to back sessions with slotted rotors.
I had the EBC red stuff pads & slotted rotors, definitely not a good combo for the track. Especially combined with my inexperience and a decent amount of slower traffic on the course. I literally melted them. Ran into traffic and started braking way to early...
Even got the calipers
Notice the grooves...mmmm
I do have Megan Racing coilovers and adjustable sway bar end links (not corner balanced, yet)...and a summer tire
Tire wear was very minimal on the almost new set of tires. Only got in 4 sessions at 20 minutes each...skipped a couple for brake cooling.
Did ruin a tire because the aftermarket lugs I used expanded with the heat and worked a little loose causing some bad scrubbing.
Learned a lot my first time out and can't wait to go again. Making plans now for a few events next year....I will be much more prepared.
I change my fluids all the time...I've changed oil with less than 500 miles on it. PTU has been changed 3 times in last 25k...Trans twice.
If I feel I've heated the fluids up to an extreme...they get changed
