Ecoboost Performance
Troubleshooting, Maintenance, TSB Articles
Troubleshooting
red clip in the connector that goes into the ignition coil...
Started by staged_sho, November 03, 2015, 10:50:19 AM
staged_sho
Full Member
Ecobooster
..broke it...so it is loosely connected to the ignition coil.
Searched Tasca but I only see a part for the entire harness assembly.
is this connector a part of its own?
Current: 2016 Charger RT Scat Pack
Previous: 2011 SHO, LME 4+X, 3 bar, 170° TStat, Intake, Corsa
Forum Supporters
Re: red clip in the connector that goes into the ignition coil...
November 03, 2015, 11:10:15 AM
I have the same question, as I have been unable to find it as a separate part. Shouldn't affect anything though, the bolt that holds down the coil does need to be properly torqued though. Very little chance it will come loose.
r1crusher
Full Member
Ecobooster
November 03, 2015, 11:14:27 AM
I broke one of mine as well. The connector itself locks onto the coil and the red clip just keeps the tab from being depressed thusly disconnecting from the coil. I've had no issues with the one missing red clip so I don't think you'll have any future problems. If you're worried just slap a zip tie around the connector and coil so it won't disconnect, problem solved.
'13 SHO, AJP Tune w/ 3-Bar
'17 F-250 6.7 PowerStroke
'17 XSport
staged_sho
Full Member
Ecobooster
November 03, 2015, 11:33:01 AM
Thanks for the replies....well...the connector slides back and forth...so the tab that locks into place is the issue too.
Forum Supporter
Forum Supporters
Trap Speed of almost 116 mph.
#4
November 03, 2015, 11:50:16 AM
Last Edit
: November 03, 2015, 11:53:26 AM by ZSHO
I agree with r1 crusher,you can use a mini ziptie to hold it in place,but the other option which is more cost effective would be ton purchase the harness connector and use the red tab. Z
https://www.rockauto.com/catalog/moreinfo.php?pk=4846353&cc=1503823&jnid=620&jpid=0
18.00 or so,you can also ask the dealer which a buddy of mine had a couple lying around. Z
2013 Performance Package SHO| Livernois Custom Methanol Tune|3-Bar Map|Reische-170-Stat|Full Race Tial-10psi BOV in Black|PPE-Gloss Black Hot Pipes|EPP Dual Intake in Gloss Black|PPE Catted DP|Corsa Sport Cat Back Exhaust|H&R Sport-Springs|CFM Performance Billet Valve Cover Breather In Gloss Black|Llumar 20%Ceramic window Tint|MSD Ignition Coils in Black|Extreme Roof Spoiler|Redline Fluids all around|Gearhead Intercooler|
First-SHO With Direct Port Alky-VP-M1-100%-Methanol Injection|LMS-Custom-Dyno-Tuned
@ 415whp-465wtq|
Best Trap Speed of 115.54 mph|
staged_sho
Full Member
Ecobooster
#5
November 04, 2015, 09:34:43 PM
Thanks for the link!!
Troubleshooting
