Started by Adam, October 30, 2015, 09:21:42 AM
Quote from: BigPelo on May 18, 2018, 03:24:24 PMQuote from: ZSHO on May 18, 2018, 02:15:40 PMBigPelo perhaps ShoBoats thread might be more beneficial since his previous SHO was also from Canada! Dunno. Z https://www.ecoboostperformanceforum.com/index.php/topic,373.0.htmlThanks for the head-up! But the thread you referred is for switchback (which I have and working since day 1 ) but my problem is with the daytime bright light that replace the accent "fog" light. I e-mailed Drive Bright and waiting a response.
Quote from: BoostfoSHO on May 18, 2018, 04:11:43 PMHave you made sure to have the car at least with accessorie power on? I think I put mine on 92 and the car has to have at least accessorie power on or else they won't turn on. You could also call in and talk to Dan. I've had my LED light replaced warranty issue and also the controller box. Dan is great at customer service. Sent from my Moto Z (2) using Tapatalk
Quote from: BigPelo on May 18, 2018, 04:19:35 PMQuote from: BoostfoSHO on May 18, 2018, 04:11:43 PMHave you made sure to have the car at least with accessorie power on? I think I put mine on 92 and the car has to have at least accessorie power on or else they won't turn on. You could also call in and talk to Dan. I've had my LED light replaced warranty issue and also the controller box. Dan is great at customer service. Sent from my Moto Z (2) using TapatalkMy wife and I have been driving the car day and night for the pass 2 weeks since I installed the kit, the lights never lit.
Quote from: ZSHO on May 18, 2018, 04:32:08 PMThe Add a Fuse adapter requires TWO of the same identical AMP- Fuse! I found this over Taurus.net Forum,hope it helps any. Z https://www.fordtaurus.net/forums/viewtopic.php?t=17723https://www.fordtaurus.net/forums/viewtopic.php?f=41&t=17723&sid=c40770f894fbce69d52ea5e2c3d62c9f&start=20
Quote from: ZSHO on May 22, 2018, 11:31:47 AMQuote from: BigPelo on May 18, 2018, 03:24:24 PMQuote from: ZSHO on May 18, 2018, 02:15:40 PMBigPelo perhaps ShoBoats thread might be more beneficial since his previous SHO was also from Canada! Dunno. Z I think you have the ADD-A FUSE ON backwards based on the ground pin! Try Switching to the other side and see if it works. ZI tried to "reverse polarity" without success... Thanks for keeping up with suggestions!
