Drive Bright Lights Daytime Running Lamp (DRL) Lower Cathode Replacement
Started by Adam, October 30, 2015, 09:21:42 AM
Adam
Love them.  Made the car bright, made the car much more expensive looking, made the car more stylish, and it made the car more visible with both a bright DRL and a blinker you cannot miss.
The install was not bad at all. Very few tools needed.
Tools required:
Wire Strippers
plastic flat trim remover pry bar
7/16 I believe socket wrench
Time
First of all, this is a solid all included kit.  You do not need to go running to the auto parts store for one part, then another.  Totally complete kit.
1. You need to remove the cover going to the current cathode style DRL on both sides which is like 6 pop down tabs, see removed picture.  Take a pry bar and pop it out one tab at a time on both sides.
2. Take the socket and remove the 2 bolts holding the cathode style unit in place and the 3 lowest bolts on the front fender well trim.
3. Unplug cathode by reaching in via wheel well.  You can turn the steering wheel to adjust tire angle to give you the most room.
4. Remove the cathode.  This may be held in place with some basic push tabs or just fall out on its own like mine did
5.Start to wire.  pop open the fuse block right next to the air filter 2013+ find fuse 90 or 92 and remove that fuse.  Add it to the other slot on the supplied kit and plug it back in.
5.  Follow the directions.  One wire now goes to the blinker, then the yellow wire goes to the blinker on the other side using the scotch locks. Optional white wire to make the DRLs dim when the headlights are on.  I skipped this one.
6.Route the line using the supplied zip ties. I went and attached it in the front over the radiator top and tied it to the wire harness that also ran across the top.
7. Don't be discouraged when the supplied line off the ballast does not reach.  The passenger side lens comes with extra long line that once you fish up to make the connection you will have room to spare
8. plug in and bolt back on the new LED style DRL.  Now check for operation
9. stare at it and say "badass"
10. put the bolts back in place in the fender well.  and put the beauty cover back over top on the bumper around the new led DRL
That is it, you are done.
If you bought the courtesy kit as well, you snip off the line right at the fuse part of the ballast about 4" in where the connector already is.  Use the wire stripper to put on the new supplied line, plug it back into the fuse block. close up the block and attach the new blue wire to the drivers side blinker function again.  You will have a great running kit.
Adam
OEM Kit trim removal
Backside of lower valance trim piece
Remove the 2 bolts that hold the light in place
Out with the Old. In with the New
Can you tell which side is complete?
Connection directly to the battery
Location under the fuse block 2013+
Adam
Passenger side yellow wire connection to turn signal orange bulb wire
Here it is at night.  Outside my workshop spare 2 car garage
They are even in height and all.  It is the actual slope of the driveway that makes one then the other appear to be pointing higher.
Light output just from the DRL.  Super bright!
Here is the 6000K bulbs and DRLs.  Looks Amazing together
The light on the ground is just from the DRL.  Look at that output.  Like a GOOD fog light.
BigPelo
This has been on "mod wish list" for a while. Thank you for the how-to. I would do it sooner but money...
Week-end family transporter: 2013 SHO tuxedo black, performance package, unleashed custom 94 octane tune, K&N Typhoon intake, 170F thermostat, 3 bar MAP sensor, SP534 spark plugs, 5000K HID Morimoto mini D2S projectors retrofit, tinted windows, Full LED lighting in and out, Eibach springs
Daily beater: 2002 WRX wagon swap JDM STi v7 20G'd
Adam
Quote from: BigPelo on October 30, 2015, 03:11:59 PM
Save up!  Worth every penny they ask for them.  To be honest, the harness in the box looks almost intimidating.  Once stretched out I was like ok I got this.  Looks great.  Had one Taurus guy say he liked what they did with the lights on the new model year.  I said I put them in, he asked for a link.  It is pretty darn awesome.  The light output helps out a ton as well.
Adam
Quote from: SHOdded on October 30, 2015, 05:55:18 PM
Hope Adam doesn't mind my adding these links to this HowTo :)
More examples of the DriveBright DRL's/light bars installed here
http://www.ecoboostperformanceforum.com/index.php/topic,4439.0.html
http://www.ecoboostperformanceforum.com/index.php/topic,4487.0.html
Q on the Bezel here
http://www.ecoboostperformanceforum.com/index.php/topic,5263.0.html
Go for it.  Props given where props are due.  This product is truly fantastic.  Good stuff you posted.  I am new and not trying to repeat, but I did not see much of a detail write up.  Some good info that got me to order the kit, but i wanted to show some of the pictures that were not shown.  AWESOME links though.
Beaster1174
With this kit, do the DRLs stay on with the key? I would like that, because stock they are only on with the headlights.
2012 SHO Sterling Gray. Temporarily stock, stay tuned.
Quote from: Beaster1174 on October 31, 2015, 05:39:16 PM
On any time the ignition is on... And they come in switchbacks, plus can be wired to flash with locking, opening door, etc.
Adam
Just wanted to update.  Not one issue since putting system in the car.  Still bright, still working flawless, still a lot of bang for the buck.
metroplex
Do we need to mess with the stock wiring if we just want to use the white LED function or is it required only for the turn signal option? Can they be used as fog lights or are they just really bright DRLs?
Previously: 2014 SHO
12.4 @ 110.9 mph
Current: 2017 Fusion Sport
BigPelo
Finally had a chance to install my kit couple weeks ago. I can't get the lights on! Instructions are well written and I am not new to car electricity so I blame my car being a Canadian model with retrofitted HID projectors in place of the halogens... Anyone knows if the Canadian cars have the same fuses box as the american models? I tried both 90 and 92 fuses, even tried to change the polarity. I am lost!
BigPelo perhaps ShoBoats thread might be more beneficial since his previous SHO was also from Canada! Dunno.  Z  :)
https://www.ecoboostperformanceforum.com/index.php/topic,373.0.html
BigPelo
Quote from: ZSHO on May 18, 2018, 02:15:40 PM
Thanks for the head-up! But the thread you referred is for switchback (which I have and working since day 1 :) ) but my problem is with the daytime bright light that replace the accent "fog" light. I e-mailed Drive Bright and waiting a response.
