Ecoboost Vendor Section
Ecoboost Vendors
Eco Power Parts
Billet compressor wheels for transverse ecoboost 3.5L
Started by EcoPowerParts, October 19, 2015, 12:07:26 PM
3
66 Galaxie
Sr. Member
Ecobooster
Re: Billet compressor wheels for transverse ecoboost 3.5L
#30
March 25, 2016, 07:44:40 PM
Assuming original shaft assembly is balanced without the stock impeller than adding a new balanced unit should be as simple as you expect. You'll want to try to track down torque spec for the nut and probably need high temp loctite or other thread locker.
Sabtaj1
Full Member
MANIVAN
#31
March 25, 2016, 07:53:46 PM
That's what I was thinking as well. I don't see why they would be any different than the f150 but a little smaller. I plan to bite the bullet as soon as my 22's are gone.
13 Eco flex.
Scott4957
Ecobooster
#32
March 25, 2016, 10:41:51 PM
In for updates on this. I had assumed there was much more too this. So you don't need a bunch of downtime, shipping, a shop etc to swap out the wheels? I like the idea of this and downpipes with a pinch of E85 over meth.
2013 Lincoln MKS EcoBoost, AJP Tuned
66 Galaxie
Sr. Member
Ecobooster
#33
March 25, 2016, 10:42:36 PM
The R&R seems pretty simple. The hardest part will probably be setting the waste gates.
SCT dealer and custom calibrator 3.5 ecoboost specialist
Vendor
Log Warlock
#34
March 25, 2016, 11:31:00 PM
If the sho wasnt my daily id love to get wheels or turbos...if mine ever blow i may grab some...there should be good gains without e85...if the wheels are that much different then they will be moving more air at the same psi ...so 15 psi would be even better than stock turbo 15 psi and there is plenty of fuel in the stock sytem above 3k
How can I help you today?
Vendor
#35
March 26, 2016, 06:51:56 PM
I talked to my supplier, best case is of course to get the turbos balanced which occurs with the $1600 setup along with new WGA and turbos being rebuilt with better seals.
Whatever you guys want to do, just let me know.
Mike B |
info@ecopowerparts.com
Please email me via
if you have any questions on new or existing orders, PM's via the forum are hard to track your purchase as I can't relate user name to actual name.
3
Ecoboost Vendors
Eco Power Parts
