Billet compressor wheels for transverse ecoboost 3.5L
Started by EcoPowerParts, October 19, 2015, 12:07:26 PM
I've been able to secure some upgraded compressor wheels for the GT15 turbos used on 3.5L transverse (SHO/Flex/MKT/MKS/Explorer Sport).
These compressor wheels allow you to get an additional 2-3 psi down low and hold to 19 psi on the top end of the RPM range.
I tested these on my Flex and ran 12.3 at very high DA.
Usually I sell this as a mail your turbo in option but I can now source the wheels for you to do the upgrade yourself.
As an introductory special I will offer these at $100 off - $500 for the first 30 days.
http://www.ecopowerparts.com/shop/index.php?main_page=product_info&cPath=1&products_id=142
I also have Turbosmart 7PSI Wastegates to allow for better boost control with the larger compressor wheels available here:
http://www.ecopowerparts.com/shop/index.php?main_page=product_info&cPath=1&products_id=143
These are in stock and ready to ship!
Nice!  Is this a DIY task or best left to a pro?  This would make a nice addition to the HOW TO section ;)
If someone were to feel comfortable pulling the turbos then changing the compressor wheel is easy.
This video will be really close to the same thing:
! No longer available
It looks like the stocker has a slot cut into it at the top that I don't see on the billet unit.
Does that affect anything?
Quote from: FoMoCoSHO on October 19, 2015, 12:51:35 PM
Nope, they bolt right on :)
Just FYI here's my Flex using these compressor wheels, huge boost improvement over stock:
Sabtaj1
Ok...  You have peaked my interest on the impeller.  But I'm curious about the wastegate. Since the stock is only 4psi.  Will this need to be changed as well??  Cause if I remember right they were upgraded to 7psi ones on your upgraded turbo option....  And at 19psi are the turbos maxed out with the new blades or are they running at a safe psi where they will last?  Thanks
13 Eco flex.
hawkeye93
2015 Ford Taurus SHO PP 12.219@112.84
PPE catless DP, Gearhead IC, SP-534, Reische 170, 3 bar, hybrid meth system, tunes from Unleashed, Livernois, Brew City Boost & AJP
1965 Ford Mustang Convertible 289 4V/T5Z/3.55
1955 Ford Fairlane Club Sedan 272 4V/Fordomatic
I'm checking into supplying the wastegate as an option.
I would suggest a tune update as with the additional boost you will probably hit torque limiters.
Quinid
Awww man..... I want so bad, but I need to drop  $1K on tires this week.....
2014 Blue Flex 303A Appearance package all stock
2000 F250 XLT 7.3L 410k miles
SOLD--2010 nonPP SHO  Unleashed 93 tune, 3 bar map, K&N drop in filter. PPE Catted Downpipes. VTA mod
1957 Chevy 3200 pickup 3 speed stock straight 6
1968 Camaro RS 3 speed 350 sb with vortec heads.
So 2-3 more down low, does response time change, will there be any more lag?
With this change will the turbos be inside of their efficiency range at 19PSI?
OT question....how in the hell was the refresh rate so fast on that Torque setup?
I'm on an OBDMX with a powerful quad core tab and I can't get it to refresh that fast.
I have seen ForScan pull 27 ms refreshes with the Bluetooth MX.  Can't go below 100 ms with Torque Pro, so no comment on that.  Using the original Nexus 7.  And yes, I am polling 25-30 parameters at any given time.
Will this upgrade need to be balanced with the turbine wheel?
Gray Brick
Can you supply compressor maps for the stock vs. new impeller?
2013 Ecoboost Ford Flex
