New Sync Update
Started by CroR1, October 10, 2015, 08:01:53 PM
66 Galaxie
Double check that you have notifications turned on for messages on your phone
Boggus
It has before and yes notifications    Is on
2013 unleashed SHO PP
Vortech347
In my wife's 2011 Limited (which I think is the same setup as the 10-12 SHO's) It will show/read texts from her 5S no problem.  My 13' won't.  Makes me a sad panda.
Matt H.
2017 F150 XLT 5.0
Boggus
Did the USB reboot and also tried the battery trick, still night time camera is crap
Quote from: Boggus on October 15, 2015, 02:12:12 AM
If your issues are mostly at night might want to consider checking if one or both of the reverse lamps are not operating,also not sure if you had the rear license plate lamp assembly recall done.  Z
slurppie
Boggus, while it's not 1080P quality it's not that bad and much better quality than my wife's Hyundai. How does your video compare to mine?
2013 w/PP
Synthetic blinker fluid
Ceramic muffler bearings
Boggus
#36
I'll take a photo tonight and compare.  Mine seems more hazy.  Again, this is an issue that popped up with the update.  It's always been decent to where I can use it .
Lamp recall has been done some time and both reverse lights work.
Boggus
Also, text message from my 6S are coming thru again, sync reads them and alerts me.
Vortech347
Quote from: Boggus on October 26, 2015, 09:50:29 PM
How did you get this to work? My 13' won't work with my 5S.  My older version sync (2011) escape does them just fine!
Matt H.
2017 F150 XLT 5.0
CroR1
Go into your iPhone settings, Bluetooth, and find SYNC. Click on the i, info icon on the SYNC, and there you should see an option that states  allow SYNC notification.
Quote from: Vortech347 on October 27, 2015, 06:04:31 PM
Vortech347
Quote from: CroR1 on October 27, 2015, 06:16:57 PM
Just checked what you mentioned.  My "show notifications" was in fact turned off!!  If this works you're my hero.
Matt H.
2017 F150 XLT 5.0
CroR1
It should, unless you carry bad luck on your back.  :alkashi:
I have yet to test mine, hopefully this weekend.
Quote from: Vortech347 on October 27, 2015, 08:32:25 PM
Vortech347
It works!!!  Thanks gents.
Matt H.
2017 F150 XLT 5.0
I think there is also a TSB on this discussion for those of you that are still having issues.  Z    TSB #ASI-45215
NHTSA ID #10058604
Date Announced:
JULY 01 2015
Additional Info:
How to Fix
Summary: FORD/LINCOLN: GLOBAL POSITIONING SATELLITE MODULE (GPSM) NEEDS REPROGRAMMING TO LATEST CALIBRATION DUE TO VOICE PROMPT FAILING TO LOCATING VEHICLE, SCREEN MESSAGE INDICATOR FAULT OF NAVIGATION, INSTEAD OF CURRENT LOCATION INDICATES PREVIOU
