New Sync Update
Started by CroR1, October 10, 2015, 08:01:53 PM
PokerMunkee
The backup camera has always been pretty bad.  My wife's '15 Armada's camera is 10x better, even at night it's great.
2011 F-250 6.2 CCSB FX4
I had a 14 taurus loaner for a couple of days in the summer,the back up camera seemed like having a 1080p quality compared to mine,but knowing the the screen is dis-continued really makes me wonder whats in store!!!!.  Z
slurppie
For you guys with the update and reporting bad camera resolution, have you rebooted the system to see if that fixes things? I've  noticed that mine would become pixilated/granular looking while at night which would coincide with the system becoming "lethargic". Using the USB reboot software would fix both issues.
2013 w/PP
Synthetic blinker fluid
Ceramic muffler bearings
Quote from: slurppie on October 12, 2015, 01:12:33 PM
Details on the reboot? Is it on the manual?
slurppie
#19
Quote from: BiGMaC on October 12, 2015, 02:28:29 PM
Negative sir. It's software that you run via a USB drive that causes the MFT/Sync system to perform a reboot the next time you start the car. I believe Ford support originally put it out a few years ago. I use it occasionally when I notice things are starting to act up. Not sure if I can post the file here but will be happy to email it tonight if you or anyone wants it.
Edit: found the file and zipped it up
2013 w/PP
r1crusher
I will have to try this reboot thing as my backup camera looks like ass compared to the wife's F150 tiny mirror backup camera.
'13 SHO, AJP Tune w/ 3-Bar
'17 F-250 6.7 PowerStroke
'17 XSport
I usually try to do a master reset of the APIM via the MFT screen or shut the vehicle off and disconnect the negative terminal on the battery for about ac minute,either of the two mentioned will cause the the APIM to reboot,bring up the (SYNC)maintenance screen.  Z
Boggus
Do I need to unzip it or will SYNC use the zip file?  Will it erase all my settings/screen savers, etc?  Night time is pixelated and it's never been that bad.  Makes it hard to judge things going backwards
2013 unleashed SHO PP
slurppie
Unzip the files to a blank USB drive - there should be 3 files if i recall. One of the files is a readme.txt file which provides additional info on what to do/expect.
2013 w/PP
Quote from: slurppie on October 12, 2015, 02:34:49 PM
If it's for the '13 SHO and up please email it. Email is in the member area. TIA
I just logged into my Ford account which i do pretty often and under recalls found the following.     FSA Title: SYNC WITH MYFORD/MYLINCOLN TOUCH - WARRANTY EXTENSION COVERING ACCESSORY PROTOCOL INTERFACE MODULE (APIM)
Field Service Action Number: 12M02
Be advised that this system tracks Recalls and Customer Satisfaction Programs for which vehicles are subject to repair in the United States. The information provided is subject to change and update. There may be temporary delays in update of information on this site due to a number of factors. For the latest information regarding the status of your vehicle or any recall program of Ford Motor Company, please contact your local dealership directly or the Customer Relationship Center.
A recall is an action by the Company to remedy a safety concern related to a vehicle defect or regulatory requirement. It may require that you return your vehicle to the dealer for service. If your vehicle is not affected, it may be because it was built at a different time or using a different part than the affected vehicles.   Z
USMCSHO341
Logged in to myford and there was an update for my 2010 SHO. Once I get her back I'll be doing the install. Thanks to the OP for bringing this up.
Boggus
Ever since I got an IPhone 6, my text messages never get acknowledged on Sync and no longer read out to me.  Now about 2 weeks ago I had some issues and after several resets the radio began working again.  When it all started acting right again, it began reading text messages again.
So, got a 6S and now I have nothing again....been thru resets, updates, reboots and voodoo magic.  Still no text acknowledged as of today.
Help
navbtcret
Quote from: Boggus on October 13, 2015, 11:38:17 PM
Help
Sync will not show or speak your text with Apple products.
2013 SHO Non PP, LMS 93 Performance v8, 3 Bar MAP, 170 Stat, MDesign CAI, Hot Pipes with TiAL BOV, PPE Catted Downpipes
