February 28, 2020, 05:53:40 PM
Author Topic: WIRE PASS THRU  (Read 11422 times)
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1838
  • -Received: 3896
WIRE PASS THRU
« on: October 01, 2015, 04:45:15 PM »
I'm not sure if there is an exact thread on this topic but might find it useful,beneficial for anyone trying to run wires from the engine bay through the firewall and dashboard,hope this helps someone out.  Z         https://www.fleet.ford.com/truckbbas/non-html/2012/P-001_2013_Police_Interceptor_Wire_Harness_Pass-Through.pdf
Offline FoMoCoSHO
  • Super Moderator
  • : South West Ohio
  • -Given: 670
  • -Received: 1136
Re: WIRE PASS THRU
« Reply #1 on: October 01, 2015, 05:23:40 PM »
Thanks Z!
I didn't know this and we punched a hole in the 2013's fire wall.....oops!
2018 Cmax Titanium Hybrid (Prius Slayer)
Needs Ecoboost
22PLE Glass Coating
2011 Lincoln MKS Ecoboost Package (Play)
AJPTurbo FFV Calibration
15 PSI, 27 Degrees, Full Rail
Full GEN V Brake Ugrade
EBC Slotted w/RED Pads
MRT Axle Back
Gone but not forgotten...
2013 Tuxedo Black non-PP SHO
2015 Bronze Fire PP SHO
Offline FoMoCoSHO
  • Super Moderator
  • : South West Ohio
  • -Given: 670
  • -Received: 1136
Re: WIRE PASS THRU
« Reply #2 on: October 01, 2015, 06:30:06 PM »
Sweet!
Needs Ecoboost
22PLE Glass Coating
MRT Axle Back
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 12530
  • -Received: 4118
Re: WIRE PASS THRU
« Reply #3 on: October 01, 2015, 06:57:51 PM »
Nice finds, Z.  Lanson had mentioned an existing passthrough on the driverside firewall at one point during his audio install for the Flex.  Don't have diagrams for that though.
Offline Sabtaj1
  • Full Member
  • : Quad Cities
  • -Given: 33
  • -Received: 93
  • MANIVAN
Re: WIRE PASS THRU
« Reply #4 on: October 01, 2015, 07:00:32 PM »
I ran my on my flex threw where the hood release cable goes. Was a pia but worked perfectly.
13 Eco flex.
Stainless works non cat DP/ MRT axle back/ Airaid cai/ 170 T-stat/ 3 bar map/ 1 step colder plugs/ snow stage 3/ hot pipes w/TIAL BOV/ torrie tuned-SCT/
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1838
  • -Received: 3896
Re: WIRE PASS THRU
« Reply #5 on: October 01, 2015, 07:04:07 PM »
Definetly making that Meth install much more feasible and tempting.  Z
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1838
  • -Received: 3896
Re: WIRE PASS THRU
« Reply #6 on: October 01, 2015, 07:31:28 PM »
I was figuring since there is a rear power access in the trunk area,is it in any way viable to add(install)a meth reservoir or any other associated components for a simpler detailed procedure,pic highlighted below on the placement,just a thought.  Z
« Last Edit: October 01, 2015, 07:36:00 PM by ZSHO »
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • : Gilbert - SE Phoenix Metro Area
  • -Given: 1155
  • -Received: 705
Re: WIRE PASS THRU
« Reply #7 on: October 01, 2015, 08:31:34 PM »
Here's a link to pics of a trunk meth install that Julio of AlkyControls did... It's on his FB page... https://www.facebook.com/media/set/?set=a.427498004121598.1073741828.408776599327072&type=3
ē2013 Taurus SHO nonPP - All Ford factory options, 3BAR MAP, LMS v8 tune (mods for 3BAR, DPs, and T-stat), Paint & plastic correction, CQuart finest all exterior surfaces, limo black window tint,VLED Triton switchbacks, Daytime BrightLites switchback DRLs, full interior and exterior LED conversion, Lamin-X charcoal blackout tail lights and reflectors, PPE catted and coated downpipes, EBPP coated hotpipes with BoVs VTA, MDesign CAI
ē2013 F250 CC Lariat 6.7EB Diesel -stock
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1838
  • -Received: 3896
Re: WIRE PASS THRU
« Reply #8 on: October 02, 2015, 05:44:47 AM »
Thanks Tom,not a fan of social media,dont like Face but do like books.lol  Z
Offline shotime99
  • Full Member
  • : Calgary, Alberta, Canada eh!
  • -Given: 29
  • -Received: 7
Re: WIRE PASS THRU
« Reply #9 on: October 02, 2015, 04:25:00 PM »
Thanks Z!
My pleasure,also found out where the rear power access is located in the trunk,pics below.  Z
WHAT??? power access in the trunk? where is that? I have no such thing in my car?
2014 Taurus SHO w/PP and H & R spring kit
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1838
  • -Received: 3896
Re: WIRE PASS THRU
« Reply #10 on: October 02, 2015, 04:32:59 PM »
Thanks Z!
Based on the pics and info it should be on the drivers side trunk area,BTW your the member that installed the battery in the trunk correct?   Z
Offline FoMoCoSHO
  • Super Moderator
  • : South West Ohio
  • -Given: 670
  • -Received: 1136
Re: WIRE PASS THRU
« Reply #11 on: October 02, 2015, 05:25:24 PM »
It is not there on the 2015 either.
I suspect it is police interceptor only so they can hook up accessories...
Needs Ecoboost
22PLE Glass Coating
MRT Axle Back
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1838
  • -Received: 3896
Re: WIRE PASS THRU
« Reply #12 on: October 02, 2015, 05:34:17 PM »
I wish i can check mine but dealing with a nasty storm at the moment,BTW your statement makes sense,(my bad)sorry about that.  Z
Offline FoMoCoSHO
  • Super Moderator
  • : South West Ohio
  • -Given: 670
  • -Received: 1136
Re: WIRE PASS THRU
« Reply #13 on: October 02, 2015, 05:45:14 PM »
No worries, it gave me a reason to mess with my car which i haven't done in weeks...
Needs Ecoboost
22PLE Glass Coating
MRT Axle Back
Offline shotime99
  • Full Member
  • -Given: 29
  • -Received: 7
Re: WIRE PASS THRU
« Reply #14 on: October 13, 2015, 11:43:02 AM »
Thanks Z!
sorry for the delay.. but yes I have the battery in the trunk and was pretty sure I had all the secret carpet and covers up when I did it.. Def is not in the trunk.. so ya must be police cars only. Would of been decent to have that there tho!
* Featured Topics
* Recent Topics
by 802SHO | Today at 05:45:47 PM
Purchased 13+ Exhaust Manifolds.  To ensure they are the good one...
Re: Misfiring codes P0300, P0302 and P0306
by ddlopes | February 27, 2020, 08:03:16 PM
Awesome!Thank you! Iím so glad it wasnít a fuel injector issue. That w...
Meth nozzle not flush
by ChrisxHowe | February 27, 2020, 03:06:59 PM
Before I get this bung welded on my hot pipes I test fitted the nozzle...
Re: PTP Turbo blanket update for the SHO
by 802SHO | February 26, 2020, 06:25:07 PM
For those waiting on an update of the PTP turbo blankets they are read...
by 10ECOMKS | February 26, 2020, 05:29:52 PM
I just bought a pair of Catted PPE DP's from Vivid Racing for ano...
Re: Battery charge?
by Gjkrisa | February 26, 2020, 08:46:26 AM
I remember seeing something on the cables that looked like a permanent...
Re: SuperPete SHO Build record
by SuperPete | February 25, 2020, 09:19:48 PM
Another video,1/4 mile Dragy showed 12.4 seconds, need to shave anothe...
by bamsho | February 25, 2020, 06:03:27 PM
That's a pretty box, glad I know what's in it, hehe...
Re: 2014 Lincoln MKS EcoBoost with all the goodies $12,900.
by SHOdded | February 25, 2020, 04:38:20 PM
Well, at least you get to move forward!  Good luck with your new ...
Re: Note to self-beware of Tesla
by sm105k | February 25, 2020, 07:03:56 AM
Yep I only have one L in the street light to street light Grand Prix s...
Re: Wrapping intake pipe, numbers are out<<<
by Davidsiebert2 | February 25, 2020, 06:15:54 AM
@SuperPete Thatís because the wrap you used doesnít do much for a radi...
Re: Xdi hpfp
by ChrisxHowe | February 25, 2020, 02:36:03 AM
https://m.facebook.com/groups/823281341395712?view=permalink&id=12...
Are You Organizing a Car Show or Other Auto Related Event?
by RockAuto | February 24, 2020, 12:33:40 PM
RockAuto would love to work with your upcoming car show, cruise-in, sw...
Re: PTU, what's inside and why my 26K mi put took a dump
by SHOdded | February 24, 2020, 12:24:17 PM
the dealer will send you the latest revision even if not so listed on ...
Re: Mustang 5.0
by SHOdded | February 23, 2020, 02:02:09 PM
Hope the dentist is a good one!...
Back to top
